time not changing
julio
I was going to install the Updates Wizard file but it tells me that the hardware is not supported by Cisco. The hardware is approved Cisco, but perhaps the updates file doesn't support the current CM version along with the hardware platform.
I'm running CM 4.1(3).
6 Replies 6
Jaime Valencia
what update wizard?? i know of an update wizard for unity but no for CCM
javalenc
if this helps, please rate
java
the files to update the patches in CCM. Never mind, do you know of a way? when i change the time on the OS it doesn't change it on the phones.
there are several causes for that, CUCM not being DST compliant, not having the right date/time group, 3rd G phones without the DST load, OS not being DST patched
javalenc
java
Hello javalenc,
Stumbled across this post....where HAS the Unity update wizard download moved to???? I can't find it anywhere.
Jason
hopefully the link won't break:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=2.0(9)&mdfid=280391779&sftType=Microsoft%20Updates%20for%20Cisco%20Unity/Unity%20Connection&optPlat=null&nodecount=2&edesignator=null&modelName=Cisco%20Unity%20Version%204.2&treeMdfId=278875240&treeName=Voice%20and%20Unified%20Communications&modifmdfid=null&imname=null&hybrid=Y&imst=N&lr=Y
if it breaks, go to the SW page and follow this path:
Voice and Unified Communications > Cisco Unity Version 4.2 > Microsoft Updates for Cisco Unity/Unity Connection > 2.0(9)
javalenc
java
UGH!! Thank you!! My old link sent me to the new menu and I was stopping at 'Cisco Unity' assuming it would be listed there.
Thanks for the prompt response!!
Jason
