Time of Day call forwarding.
I'm trying to call forward a translation pattern to a hunt pilot only after hours.  I have created time periods, schedules, partitions and have adjusted the translation pattern accordingly, but I believe I am missing something as it is not taking effect (CTI Route Point?).  Here is what I have created regarding the translation patterns which are identical, but on different partitions.
(normal hours 8am - 5pm)
Translation Pattern =  5555
Partition = PT_Default
Calling Search Space = Internal-CSS
Called Party Transform Mask = 1900
(after hours 5pm - 8am)
Partition = PT_AfterHours
Called Party Transform Mask = 1905
Essentially, I am trying to call translation pattern 5555 from 1900 during normal hours, to 1905 (hunt pilot) after hours.
I created two time periods (TP_After1 and TP_After2) which cover from 1700 - 2400 and 0000 - 0800 respectively and placed them a time schedule called TS_AfterHours.  I placed that in a new partition called PT_AfterHours.
I'm stuck now as I don't know how to make call manager (v6.1) recognize the second pattern to take over after hours.  I read about creating a CTI route point, but am not sure the settings to use.  Can anyone assist?  Thanks!
And have you already added
To the CSS of the devices that you want to get that behavior???
Can't see anything mentioning you have done that.
This config works with anything, it does not need a CTI RP to work, a TP works just as well as a CTI RP.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Super Bronze
Also if you have added the partitions to each CSS make sure you have added the 'after hours' one ABOVE the 'default' one. Otherwise the default will always be matched, as it is always 'active'.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
557
