Community Member
Time of day routing problem
HI,
We have CUCM7 and i m trying to configure time of day routing to CTI route point XXXXXXX665. In businesshrs 8-16 i want call to be forwarded to number
XXXXXXX740 and after hours 16-08 to XXXXXXX741. The problem is that when i call CTI route point number it only says number cannot be dialed. Anyone knows solution for this?
I created following:
3 Time periods:
TP_businesshrs:                Mon-fri 8-16
TP_nobusinesshrs1:          Mon-fri 16-24
TP_nobusinesshrs2:          Mon-fri 00-08
2 Time schedules:
TS_businesshrs:              TP_businesshr
TS_nobusinesshrs:          TP_nobusinesshrs1 & TP_nobusinesshrs2
2 Partitions:
PAR_businesshrs:              TS_businesshrs
PAR_nobusinesshrs:          TS_nobusinesshrs
1 Calling search space:
CSS1:                              PAR_businesshrs & PAR_nobusinesshrs
I added CSS1 to the CTI route point. I created 2 665DN and added each DN to newly created partitions.
Thanks in advance.
Everyone's tags (4)
Hi.
CSS1 containing those two partitions, should be assigned to ip phones or voice gateways which are calling that RP.
Try to check it and let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Community Member
The calling phone does have mentioned CSS assigned. Also tried to call RP with and without CSS.
Re: Time of day routing problem
Hi.
Instead of a CTI route point, add two translation pattern respectively assigned to PAR_businesshrs and PAR_nobusinesshrs you should obtain the expected result.
Don't forget to assign a valid css to TP in order to reach desired forwarded destination.
Carlo
Community Member
I want to do this to CTI route point because it is a customer line.
Ok. so in this case, check the CSS of Call Forward All field in DN config . That CSS should allow that DN to forward calls to desired destination.
Let me know
Carlo
Create two dummy translation patterns and give each one the respective partition and translate the called number to desired destination with the righ CSS to reach that number
In the CTI set the call forward all to the above translation dummy number and provide it the call forward all CSS as CSS1
Community Member
I tested again just in case and internal calls to 665 works properly . But if i try to call with cellphone to XXXXXXX665, it wont work. You happen to know why?
And back to your instructions:
Never ever created translation patterns....Please check if i created them properly.
7XX
PAR_businesshrs
Called Party Transform Mask: 740
7XX
PAR_nobusinesshrs
Called Party Transform Mask: 741
What do you mean? How do you assing CSS to TP? i thought you can only assign TS to CSS...
marwanshawi wrote:
....provide it the call forward all CSS as CSS1
I only have CSS1. So do you want me to create new one?
PS. sorry for stupid questions. I m kinda new to this...
Hi.
When you configure a translation pattern, you have to specify both partition and CSS in order to allow TP to reach called party transform mask destination.
Carlo
Hi.
I tried for you the following config in my lab.
Time Period Day 08:00 - 18:00
Time Period Evening 18:00 - 24:00
Time period Night 00:00 - 08:00
TS Day:  TP_Day
TS Night: TP_Eveneing & TP_Night.
Partition Day_PT TS Day
Partition Night_PT TS Night
Css: CSS1 with Day_PT , Night_PT and Internal_PT
CTI RP_Day
DN:700
Partition Day_PT
CSS: Css1
Call forward all set to 750  and CSS set to CSS1 (750 is a directory number in Internal_PT partition
of an internal ip phone)
CTI RP_Night
DN:700
Partition Night_PT
CSS: Css1
Call forward all set to 751  and CSS set to CSS1 (751 is another directory number in Internal_PT partition
Test ip phone:
DN:200
Partition: Internal_PT
CSS:Css1
H323 Gateway:
Calling search space:CSS1
Both internal (calling 700)  and external (XXXXXXX700) calls works fine.
Carlo
Community Member
Your setup also does the same....I think i have done eveything right but someting is blocking my external call when i add partition to DN.
Check the CSS assigned to your  Voice gateway a see if both internal extensions and new CTI RP created can be reached from this VG.
Carlo
Community Member
Never even modified gateway. Weird thing is i can't find any devices under gateway but i can find gateways under trunks. I think i'll contact service provider. Thanks for the support anyway
Ok.
In trunk configuration you should find incoming calls section where you have to specify the css.
Try to check and let me know.
Carlo
Community Member
We have several same trunk configured with different route patterns . Each of them seems to use device pools CSS which is none.
972
