Community Member
Time period not changing for Time-of-Day Routing
I have Call Manager ver 4.2, I am trying to change the closing time of the Hunt list, I have changed it and updated it mutliple times but it does not start with new time.
thanks
hasrat
Re: Time period not changing for Time-of-Day Routing
It's possible the info is not refreshing in the cache, have you tried bouncing the ccm service or restarting the server?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Thank you for the reply, I did delete Time period and added it back, I will reset server after hours and update tomorrow.
thanks
hasrat
165
