Time problem on Cisco IP Phone 8941
I have a problem with the date/time on severals Cisco IP phone 8941. We are still experiencing an issue with date/time on our IP phones - it freezes on some occasions and shows the same time since then.
If the phone has a reset, or an user logs out and login again (Extension Mobility), the time phone sets to a new value and stays there.
Version  CP-8941-K9= V01
App Load ID  SCCP 9-2-3-5
CISCO CALL MANAGER
System version: 8.5.1.12900-7
Thanks for your help,
David
1 ACCEPTED SOLUTION
Have you tried to upgrade the firmware of the 8941 IP phone.
Pawan Arora
Silver
Does it show the correct time if you go under any menu options?
You are probably hitting this bug here:
8945 SCCP: Sometimes, phone doesn't update time in header
fixed in 9.3(1)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl73175
Posted by WebUser Asad Raza from Cisco Support Community App
Pawan Arora
Thanks for your help.
We will uograde firmware phone.
Best Regards,
David Lozano
288
