Time range Cor List
Hi all,
there is any option to use cor list with a time range?
Hall of Fame Super Gold
Re: Time range Cor List
Not really. If using CME, you can check if "after-hours" blocking would do for your needs, as it allow time-based configuration.
I know, but with after-hours configuration, i block fxo port too...
Actually it prevents certain phones from dialing certain calls starting with numbers you decide. FXO ports are not affected directly.
I have a cme and I want some specific phones to call only internal number on non-working hours..
Do you have an idea how I can do this?
Use after-hours to achieve that. More information can be found at this link, http://voipnewb.blogspot.se/2009/08/cme-after-hours-call-blocking.html?m=1
Please rate all useful posts.
Please remember to rate helpful responses and identify helpful or correct answers.
237
