Time required to mirror a drive in a 7835-H2
Just a quick question.
We are curious to know the approximate time that it takes to mirror a single drive on a 7835-H2. This would be by removing one drive in the array and putting in a new one.
Someone has said 30 minutes, but I felt that was maybe a little bit quick, considering these are 72gb drives.
Can anyone provide insight?
David
1 ACCEPTED SOLUTION
Re: Time required to mirror a drive in a 7835-H2
Back in the day when I had to do this sort of thing a lot, I'd say 30 minutes is pretty normal.  Occassionally 45 minutes or so.  Longer than that and I was never surprised to run into drive errors.
So, yes 30-45 minutes would be about right.  Could be faster if you up the priority of the mirror and there is low CPU utilization at the time.
Hailey
Please rate helpful posts!
Hailey
Perfect, just what we needed to know. Thank you!
169
