Time ring IP Phone
When I call an IP Phone the phone ring only four times. How to increase the number of ring before the hungup?
I have try the command timeouts ring 60 without found a solution.
1 REPLY
Hall of Fame Super Red
Re: Time ring IP Phone
Hi Pascal,
This may be where your current 4 ring setting is coming from (you probably have this set as 10-12 seconds). Have a look;
call-forward noan
To configure call forwarding so that incoming calls to an extension (ephone-dn) that does not answer are forwarded to another number, use the call-forward noan command in ephone-dn or ephone-dn-template configuration mode. To disable call forwarding, use the no form of this command.
call-forward noan target-number timeout seconds
timeout seconds - Sets the duration that a call can ring with no answer before the call is forwarded to the target number. Range is from 3 to 60000. There is no default value.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_c1ht.html#wp1063669
Hope this helps!
Rob
527
