Time Stamp on all the phones is wrong
We're running CUCM Ver 7.1.5, the time stamp on all the phones is 4 minutes fast.  How do you resolve this issue?
Phones installed include: 7962, 7942, 7911, 7912, 7937, 7940, 7941.
Joaquin
Hall of Fame Super Silver
SIP or SCCP load?
Is the time off from what CUCM is showing?
What is the firmware version?
Chris
Re: Time Stamp on all the phones is wrong
Chris
SCCP42.9-1-1SR1S
I'm new at this, where do I find the CUCM time?
Joaquin
Bronze
Use the command "show status" in the CLI or go to show > System in the OS Administration page.
Gareth
Thanks Gareth
Yes the time stamp is the same as the phones.
Joaquin
What does "utils show ntp" show? Make sure your CUCM is synched with NTP.
Chris
Chris,
I don't see "Utils" on any of the Pull Down Menus on the OS Administration page.  Under settings I see the NTP Server is the Publisher and the  Status="The NTPService is accessible".
Joaquin
This is from CLI, loging via SSH to the publisher and issue this command.
Chris
Chris,
When I issued the command "utils show ntp" at the CLI admin: prompt
The sytem returns: Executed Command unsuccessful, No valid command entered.
Joaquin
Bronze
Try:
utils ntp status
Gareth
Bronze
My guess is that you'll end up referring to a new NTP server at the end of this. Etiher a self built one, or pointing to your windows DC.
Gareth
Gareth,
OK if that's where I'm going with this I think I'll call Cisco TAC for support, I didn't think this would be such a big deal with the time stamp.  Thanks to all for the help.
Joaquin
That got it, the time stamp is four minutes fast, just like the phones.
Joaquin
Cheajt,
If your NTP is not synchronized, the phones will use the time configured on the switch that they're directly connected to. You will need to verify your NTP source to fix the synchronization.
Yosh
HTH Regards, Yosh
Bronze
There really isn't much to setting an ntp reference in CUCM. You probably already have an NTP for your existing network switches, but if not, there are plenty of examples on the interwebs. I personally set up a small VM with CentOS just for ntp services for switches and UC devices. (Linux NTP Setup). Once that is done, follow this guide to configure the publisher for the new NTP server. Note that at the end, you will have to reboot the whole cluster:
"After deleting, modifying, or adding the NTP server, you must restart all other nodes in the cluster for the changes to take affect."
Gareth.
P.S: As I've just found out, Windows NTP servers are not supported:
Cisco recommends synchronizing Unified CM with a Cisco IOS or Linux-based NTP server. Using Windows Time Services as an NTP server is not recommended or supported because Windows Time Services often use Simple Network Time Protocol (SNTP), and Linux-based Unified CM cannot successfully synchronize with SNTP.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/netstruc.html#wp1185637
Gareth,
Thanks,  I'll look over your references, but I'm thinking my problem may stem from the fact that the NTP service is running off of my two 3945 Voice Gateways and the voice devices are all on an isolated network.  The VoIP network does not connect to the regular companies network.  I'm wondering if it's possible to disable NTP and just adjust the time via the Operating Sytem Administrator web interface or if that would even work.
Joaquin
Bronze
What's your ntp reference for the 3945? Since your CUCM server gets its time from the 3945 (I wrongly assumed you were getting the time locally), that's where the issue is. Can you show us the output of:
show ntp status
and
aho ntp associaions
This will show us the time on the 3945 and where the 3945 is getting it's time from. It's really not a good idea to have a local time source for cucm... that would rely on the cmos of the server and you're way more likely to have some time slippage.
Gareth
Gareth,
See the putty log, the aho ntp associaions command didn't work.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.01.17 09:09:47 =~=~=~=~=~=~=~=~=~=~=~=
login as: Administrator
Administrator@10.28.0.6's password:
Last login: Thu Jan 16 10:08:25 2014 from 10.28.11.14
Command Line Interface is starting up, please wait ...
   Welcome to the Platform Command Line Interface
admin:show ntp status
Executed command unsuccessfully
admin:utils ntp status
ntpd (pid 18712) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*127.127.1.0     LOCAL(0)        10 l    1   64  377    0.000    0.000   0.004
x10.28.0.35      LOCAL(1)         4 u   15   64  377    0.310  -9052.7   3.949
x10.28.0.36      LOCAL(1)         4 u   28   64  377    0.300  130335.   4.214
synchronised to local net at stratum 11
   time correct to within 11 ms
   polling server every 64 s
Current time in UTC is : Fri Jan 17 15:09:07 UTC 2014
Current time in America/Chicago is : Fri Jan 17 09:09:07 CST 2014
admin:aho ntp associations
Joaquin
Bronze
Sorry... that last command was supposed to be:
show ntp associations
I'm trying to figure out exaclt where your systems are getting time info from. I'm assuming that the time on the gateway is also off?
Gareth
Gareth,
The 10.28.0.35 and 10.28.0.36  devices are my voice two gateways, the ones that connect to the PSTN and the VoIP network.  When I query the "Phone NTP references" from CUCM  Administrator web interface it list the two gateway addresses above and my publisher & subscriber servers too.  Below is the associations output from the gateway.
C
This system is company property. Unauthorized access or use is prohibited and
may be subject to discipline, civil suit or criminal prosecution. To the extent
permitted by law, system use may be monitored, recorded or disclosed and using
the system constitutes your consent to do so. You also agree to comply with
procedures for system use and protection of information, including but not
limited to proprietary information, personally identifiable information, and
export controlled information.
Using keyboard-interactive authentication.
Password:
SanAntonio-VG1#show ntp status
Clock is synchronized, stratum 4, reference is 127.127.1.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**16
reference time is D683D0B0.3AEC524A (09:54:24.230 CST Fri Jan 17 2014)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.26 msec, peer dispersion is 0.24 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is 0.000000000 s/s
system poll interval is 16, last update was 0 sec ago.
SanAntonio-VG1#show ntp asso
SanAntonio-VG1#show ntp associations
  address         ref clock       st   when   poll reach  delay  offset   disp
*~127.127.1.1     .LOCL.           3     14     16   377  0.000   0.000  0.254
~192.43.244.18   .INIT.          16      -   1024     0  0.000   0.000 15937.
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
SanAntonio-VG1#C0626B626AB4
Joaquin
Bronze
On that Gateway you've got a reference for one of the pool.ntp.org servers (192.43.244.18) which has actually been taken out of the ntp server pool http://www.pool.ntp.org/scores/192.43.244.18
Check on the NIST for other addresses you can point to.
Gareth
OK, now we're getting somewhere,
Thanks!
Joaquin
Hi.
Because NTP is a key service for CUCM and all UC platforms, you cannot remove all ntp servers from CUCM.
The command to adjust time via cli is:
date (hh:mm:ss:MM:DD:YYYY)
But it will fail to run because the presence of an NTP Server.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo,
Good to know thanks.
Joaquin
391
