time to connect a call to the pstn from cucm 8.5
Hello every one.
I wonder if someone has face something like this. I have a customer that does not like the time a call takes to get to the pstn.
We are using call manager 8.5 and h323 gateways (Using E1 cards with r2 signalling). I have adjusted the t.302 timer to 3000 ms. which is the minimum value  and I have also use the time out interdigits to 0 on the gateways voice ports.
We notice that the calls takes about 6 to 7 seconds to get established but the customer wants less time.
Any Ideas?
1 REPLY
Re: time to connect a call to the pstn from cucm 8.5
I would suspect there's some overlapping there, either in CUCM or in H323, or both.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
101
