Timeout Delay
Guys,
I need your expertise, the end-user is complaining for a big delay to thier IP phone whenever dialling any outbound calls before it connected. Is there any quick solution to rectify this issue. We tried to put a # sign at the last after dialling the number but the delay is still the same.
Any output is really appreciated.
Re: Timeout Delay
most probably you have interdigit timeout due to dial plan overlapping, if you do not add the # to the route pattern (unless using @) it won't work. only @ recognizes it automatically, any pattern that does not contain @ needs the # in the pattern
review your dial plan and take out whatever overlapping you have to fix this
use route plan report for this purpose
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Timeout Delay
Hi, Thanks for the info. Follow-up Question,
can I make a single route pattern for the following route pattern?
International:
0.00xxxxxxxxxxxx
0.00xxxxxxxxxx
0.00xxxxxxxxxxx
Thanks again
Re: Timeout Delay
0.00xxxxxxxxxxxx
any way you're going to have IDT if not dialing all the digits
leave the 3 route patterns and add #, you'll have to educate users to dial # after the numbers. this happens to all deploys since CUCM has no idea how many digits an international call needs and will wait for the IDT or the #
even using 9.@ or 9.011! has the same issue
java
java
112
