ā07-08-2013 05:28 PM - edited ā03-16-2019 06:16 PM
one of my customers asked me that if CUCM has some parameter to configure a timer to calls, it means that any active call should be dropped after certain minutes, Can i do that?
Thanks in advance.
Solved! Go to Solution.
ā07-08-2013 06:10 PM
Yes, the "Maximum Call Duration Timer" service parameter can be changed to whatever you want where the max value can be 35791 minutes, the default being 720 minutes.
HTH,
Chris
ā07-09-2013 07:07 AM
This is global and will affect all calls, no way around it on CUCM side. You could perhaps develop TCL script that terminates the call after X minutes on the GW if you are using SIP/H323 GW.
HTH, please rate all useful posts!
Chris
HTH,
Chris
ā07-09-2013 06:58 AM
Hi Chris,
thanks for your response. This parameter is global, do you know a set by extension?
Thanks in advance.
ā07-09-2013 07:01 AM
juan_cye_ccna wrote:
Hi Chris,
Thanks in advance.
As often discussed, there is no per-extension setting.
Chris
ā07-09-2013 07:19 AM
Chris,
I appreciate your help. Do you have some link to view an example code?
ā07-09-2013 07:29 AM
I do not, Paolo is the TCL expert, perhaps he has some tips :-)
Chris
