timezone setup for CP-7945G SEP.cnf.xml
dear all
i have phone 7945G and i want to configure the correct timezone which is for our country Kabul Afghanistan and the its +04 30 so can any body help me how to configure this.. in my SEP.cnf.xml file in <timeZone></timeZone> secion
regards
Waisudin Farzam IT/DataCenter Specialist P E: wfarzam@gmail.com S E: wais.farzam@gmail.com S: wais.farzam Certified Cisco ID: CSCO11404095 CCNA, CCNP, CCNA Sec, and CCIE R&S v4.0 Written Certified
  • IP Telephony
1 REPLY
In CME check the clock of router and let it peer with external NTP server.
if the NTP is in different time zone you can off set the clock by using below command in global mode.
VG(config)#clock timezone AST ?
  <-23 - 23>  Hours offset from UTC
then create cnf under ip telephony and restart the phone and it will be working.
577
