To fake_display shows up on screen on some outside calls
To fake_display shows up on screen on some outside calls. I have users who are dialing some 888 numbers and since I upgraded to 5.1.3-5000 they will get thisappearing on their screen....
“To fake_Display 18883740234”
Doesn't affect the call, but I have never seen this before.
Thoughts?
Silver
Re: To fake_display shows up on screen on some outside calls
Does 18883740234 or part of it appear in your route plan report as a device of some kind? Maybe a CTI port or something?
Cheers,
Tim
Thanks for the reply. I just found out that it is a bug in the 12.4T train we are using in our H.323 gateways.
Any options how to fix this? Can you please also share the bug id for the same.
This is a bug on the gateway:
CSCsi69413
If you upgrade IOS you should be fine.
-nick
521
