Community Member
to find the switch port
In a CM 4.1 environment how can I identify the exact switch port no., that a ip-phone is connected, without accessing any router or switch. Is there any way to find...?
Re: to find the switch port
if you mean from CUCM, there is no way to find it. CUCM does not have that info
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
thank you for your replay, java.
I mean from CUCM or ip-phone or by any means, but not by accessing any router or switch.
Community Member
There is no way to find out this information w/o getting on the switches. You would need to get on the switch and view the mac address table or use cdp to track down where the phones is plugged in.
Community Member
This probably won't help, but on CM 6.1 with CER running, you can go to CER Administration/ERL Membership/Switch Ports, find a phone, then click View. It will show the Switch IP Address, Switch HostName and Port Name.
I have no idea if there is anything like this with CM 4.1 or if you have Cisco Emergency Response going.
Silver
OPen a browser and enter the IP Address of the phone then click enter. A new page will open, on the left side click on the "network" and scroll down to the bottom of the page and look for "Neighbor Port". That's the port where your phone is connected. You can also see the switch name and the IP Address and tons of other interesting info.
MK
285
