TOD (Transferting the call to voice mail After office hours
I need to configure the TOD. After office hours i need to forward calls to voice mail. How i can do this configuration.
Sunish
1 REPLY
Re: TOD (Transferting the call to voice mail After office hours
Easiest way is to configure TOD with CTI RP and set the CFA to VM.
If you need help on TOD refer to the configuration guide for the CUCM version you have.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
214
