Toll fraud - ISP trying to hold me responsible
Small ISP in central NY.  I have 3 phone lines coming into my home.  They are delivered via 2 x cable modems (2 x FXS jacks on each cable modem).  I have connected 2 of the FXS ports on the cable modems to 2 x FXO ports on a 2811 router. I also receive my bandwidth via the cable modem.   I use connection plar opx <insert phone number here> and then define the phone number on my CUCM.
Over a two day span, someone generated 28 calls to Dominica for a total of 498 minutes.
CDR records provided to me from the ISP all show the source DN as my DN.
My CDR records from my CUCM do not show any of these calls.  My route patterns do not even allow 13 digit international dialing (max is 1plus 10 for long distance)
My CUCM is behind a NAT router with no static mappings from inside to outside.
So, other than empty CDR records and my denials, what else can I do to prove my innocence?  My belief is that the modem itself was hacked.
From the ISP, I received something that appears to be a detailed CDR record.
Report Date: 3/15/2012
Call Count: 28
Call Duration: 498 Minutes
Calling Number: DELETED - THIS WAS ONE OF MY NUMBERS
Destination: DOMINICA
Called Number: 767-275-3700 / 767-275-4477
Call Example:
1  : start-time                          = 2012-03-16 18:05:19
2  : start-time                          = 1331935519
3  : call-duration                       = 000:27:03
4  : call-source                         = 199.58.145.156
5  : call-source-q931sig-port            = 0
6  : call-dest                           = 10.2.10.40
7  : unused                              =
8  : call-source-custid                  =
9  : called-party-on-dest                = 17672753700
10 : called-party-from-src               = 17672753700
11 : call-type                           = IV
12 : unused                              = 01
13 : disconnect-error-type               = N
14 : call-error                          = 0
15 : call-error                          =
16 : unused                              =
17 : unused                              =
18 : ani                                 = DELETED - THIS WAS ONE OF MY NUMBERS
19 : unused                              =
20 : unused                              =
21 : unused                              =
22 : cdr-seq-no                          = 23442826
23 : unused                              =
24 : callid                              = 959f9128-c73a919c-13c4-50029-1110-23229e7f-1110
25 : call-hold-time                      = 000:00:05
26 : call-source-regid                   = dynamic-3539396626.865246.069
27 : call-source-uport                   = 1
28 : call-dest-regid                     = MetaSwitch01
29 : call-dest-uport                     = 0
30 : isdn-cause-code                     = 16
31 : called-party-after-src-calling-plan = 17672753700
32 : call-error-dest                     =
33 : call-error-dest                     =
34 : call-error-event-str                = ack-rx#na
35 : new-ani                             = DELETED - THIS WAS ONE OF MY NUMBERS
36 : call-duration                       = 1623
37 : incoming-leg-callid                 =
38 : protocol                            = sip
39 : cdr-type                            = end1
40 : hunting-attempts                    = 0
41 : caller-trunk-group                  =
42 : call-pdd                            = 4506
43 : h323-dest-ras-error                 =
44 : h323-dest-h225-error                =
45 : sip-dest-respcode                   =
46 : dest-trunk-group                    =
47 : call-duration-fractional            = 1623.424
48 : timezone                            = EDT
49 : msw-name                            = msx1
50 : called-party-after-transit-route    =
51 : called-party-on-dest-num-type       = 0
52 : called-party-from-src-num-type      =
53 : call-source-realm-name              = <private>
54 : call-dest-realm-name                = <private>
55 : call-dest-crname                    =
56 : call-dest-custid                    =
57 : call-zone-data                      =
58 : calling-party-on-dest-num-type      = 0
59 : calling-party-from-src-num-type     =
60 : original-isdn-cause-code            = 16
61 : packets-received-on-src-leg         = 80892
62 : packets-lost-on-src-leg             = 304
63 : packets-discarded-on-src-leg        = 303
64 : pdv-on-src-leg                      = 0
65 : codec-on-src-leg                    = g711ulaw
66 : latency-on-src-leg                  =
67 : rfactor-on-src-leg                  = 91
68 : packets-received-on-dest-leg        =
69 : packets-lost-on-dest-leg            =
70 : packets-discarded-on-dest-leg       =
71 : pdv-on-dest-leg                     =
72 : codec-on-dest-leg                   = unknown
73 : latency-on-dest-leg                 =
74 : rfactor-on-dest-leg                 =
75 : sip-src-respcode                    =
76 : peer-protocol                       = sip
77 : src-private-ip                      = 199.58.145.156
78 : dest-private-ip                     = <private>
79 : src-igrp-name                       =
80 : dest-igrp-name                      = 1
81 : diversion-info                      =
82 : custom-contact-tag                  =
83 : e911-call                           =
84 : reserved                            =
85 : reserved                            =
86 : call-release-source                 = destination
87 : hunt-attempts-including-LCF-tries   =
88 : call-gapping-error                  =
89 : error-code-in-reason-header         =
90 : ocl-object-type                     =
91 : ocl-object-id-dtn-regid-realmname   =
92 : ocl-object-id-dtnrealm-uport        =
93 : ocl-policy-name                     =
94 : src-private-port                    = 50368
95 : dest-private-port                   = 28632
96 : src-realm-media-ip                  = 68.70.57.8
97 : src-realm-media-port                = 28456
98 : dest-realm-media-ip                 = <private>
99 : dest-realm-media-port               = 22070
The ISP tells me that the 199.58.145.156 address is my cable modem/FXS ports.
Is there anything here that would help me defend myself?
Jeff
1 ACCEPTED SOLUTION
Re: Toll fraud - ISP trying to hold me responsible
Hi Jeffery,
Unfortunately, the ISP is correct. If they are nice to you, maybe they can come to some sort of settlement agreement with you as to the amount of the bill.
I have seen this happen with several of my customers.
Basically what is happening, is that phreakers (phone system hackers), are registering SIP or H323 softphones (maybe Xlite, or another type softphone) to the public IP of your 2811 router, and being able to determine that the IP resides in the US, and may more than likely use a "9" to get an outside line. Of course you have dial-peers in the router to forward these calls out of your FXO ports, and voila, the call is made!
The call will never hit your voip dial peer pointing to  CUCM, which is why you won't see anything in your CDRs
This can be remedied with an ACL applied to your internet facing interface, blocking sip and h323 traffic. Or, you can make explicit dial peers that will block calls made to notorious toll-fraud destinations (Cuba, etc).
ip access-list extended TOLL_FRAUD_BLOCK
deny tcp any any eq 5060
deny udp any any eq 5060
deny tcp any any eq 1720
deny udp any any eq 1720
permit ip any any
interface (outside/internet facing interface)
ip access-group TOLL_FRAUD_BLOCK in
Then, Im pretty sure, the next day, if you do a show access-list, you should see some hits for the deny SIP and maybe the deny H323 (I usually see this done using SIP), and you will know that you have effectively blocked the toll fraud. You will be amazed at the amount of times they tried to hit your router before they finally decide to give up. I have noticed that this usually happens during the late night hours. Also, Dominica is in the Caribbean, and therefore has a 1+10 digit numbers, which is why the router allows the call, since there is a dialpeer to match it.
Hope that helped, if so, please rate.
Hi Jeffery,
permit ip any any
Kenneth -
     I appreciate your very detailed reply and Im sorry that you have to know this from experience as well (at least your clients)
    If I read your post correct, you are presuming that the phreakers are inside my network (as that is the only way that they could be going "out" my public facing interface.
    If that is true, than one of my inside boxes has been compromised.
    I will try out your suggestion and re-post to let all know what happened.
Jeff
Kenneth -
    I just re-read your response and now realize what you are saying.  They are not inside my network, they are outside, but they are hairpinning/tromboning into and then back out of my 2811.
   That is very interesting.
   I will apply the ACLs as well as the block dial peers and see what happens
Jeff
Kenneth -
Well, I dont know if we are going to find out the real truth or not.
Through conversations with the tech guy at the ISP, they discoverd weak passwords and fixed them and also put an international block on my line (that I had requested some time ago and they did not implement). After they put the international block on my line, there were 3 attempts and then they stopped. There has been no more attempts since then.
I did place the ACL, but it has not had any hits and it appears that the culprit has moved on to other game.
Thank you anyway, its great advise and I will keep it in place.
Now, how do I place a rating in the system?
Jeff
Jeff,
I concur with Kenneth. If the situation is indeed as Kenneth predicted, then my friend it's a bad news.
GP.
VIP Super Bronze
Another option in addition to the ACLs is to upgrade to IOS 15.1(2)T or newer. They implemented a deny-by-default behavior for VoIP dial-peers. All SETUP/INVITE requests will be denied unless the source address is also a target address of a VoIP dial-peer.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
1024
