Toll Fraud Prevent
I need help to prevent toll fraud i've got IOS 12.4, I have read many sites to upgrade the IOS on 151-2.T4 but i'm not sure my Unitty Express 7.0.6 will support IOS 15.xx ??
- I dont have enough knowledge on voice please if you can help me to prevent this problem with any idea i will appreciate.
Gezim
1 ACCEPTED SOLUTION
Toll Fraud Prevent
Hi Gezim,
If CUE integrated with CUCM no need to worry about the IOS version of the Gateway.
If CUE integrated with CME on the same gateway we need to check the compatiblity between CME & CUE.
When we are going above 15.1 CME version will be 8.X . As per the compatility matrix of CUE  7.1 & aboive support CME 8.0. so in this you need to upgrade CUE also.
Find the attached link for your reference.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm#CompatibilityCMEandSRST
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Thanks in Advance...
Toll Fraud Prevent
Hi Gezim,
VIP Purple
Toll Fraud Prevent
Hi Gezim,
In addition to what GPS has said, what is module u are using?
TollFraud was introduced from IOS version 15.1(2)T , so to use Toll fraud u need to upgrade IOs .
redgs,
aman
394
