01-18-2012 12:54 AM - edited 03-16-2019 09:03 AM
On a voicegateway in India, calls to toll free numbers are failing. Although the the telephone number in the debug is correct, I'm getting an "Unallocated/unassigned number" error from the telco. I'm running software c2900-universalk9-mz.SPA.150-1.M3.bin on the voicegateway CUCM 7.1.5.
Don't have issues with calls to normal numbers (landline, mobile).
*Jan 18 08:25:26.816: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 041000001
*Jan 18 08:25:26.816: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x6A63 callID = 0xE9E4 switch = primary-net5 interface = User
*Jan 18 08:25:26.816: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x6A63
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2181, '041000001'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '18001801407'
*Jan 18 08:25:26.864: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xEA63
*Jan 18 08:25:27.560: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xEA63
Cause i = 0x8A81 - Unallocated/unassigned number
Progress Ind i = 0x8288 - In-band info or appropriate now available
Progress Ind i = 0x8282 - Destination address is non-ISDN
*Jan 18 08:25:27.560: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xE9E4
*Jan 18 08:25:27.696: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x6A63
*Jan 18 08:25:27.716: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xEA63
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn map address . plan isdn type national
no cdp enable
Solved! Go to Solution.
01-18-2012 05:27 AM
I notice that your outgoing call is sending a type of number TON to
the service provider as NATIONAL fot this call.
This may not be correct for this type of call
Can to add this piece of config below just to test
voice translation-rule 1800
rule 1 /^18/ /18/ type national unknown
voice translation-profile TEST-TOLL-FREE
translate called 1800
voice-port 0/0/0:15
translation-profile outgoing TEST-TOLL-FREE
To remove
voice-port 0/0/0:15
no translation-profile outgoing TEST-TOLL-FREE
no voice translation-profile TEST-TOLL-FREE
no voice translation-rule 1800
Try it just see if it makes a difference.
Alex
01-18-2012 03:14 AM
if you are send the correct digits to the Telco i suggest you contact them to help you.
01-18-2012 03:21 AM
All the known India toll free numbers have 6 digits after 1800, but the one above has 7.
Are you sure the number is correct ?
01-18-2012 04:26 AM
Some of them do have 7 digits as the one above from Air India/Indian Airlines
01-18-2012 05:27 AM
voice-port 0/0/0:15
To remove
voice-port 0/0/0:15
Alex
01-18-2012 07:22 AM
After changing the config as proposed and removing isdn map address . plan isdn type national under interface Serial0/0/0:15 looks like its working.
01-18-2012 07:17 AM
On their website, Air India specifies that the number is tool free only from two telcos lines.
Can you try with a 6 digits number ?
01-18-2012 07:43 AM
The Cause code "Cause i = 0x8A81" can be broken down to:-
"8A" (Cause Code Origination Point) --- a network beyond the internetworking point.
"81" (Disconnect Cause Code) -- The switch receives the ISDN number in the correct format. However, the number does not belong to destination equipment.
Try sending all calls as Type and Plan "Unkown" and let the telco decide how to route the call.This can help in international and 11 digit dialing being done here.
