TON H323 GATEWAY IN UK
Dears,
Do I have to specify the TON when configuring H.323 gateway in UK? and what it should be?
I'm getting Q.931 Disconnect Cause Codes of 28 that says:
Invalid Number Format (address incomplete).
Indicates that the called party cannot be reached because the called party number is not in a valid
format or is not complete. This can happen when you are calling out using a network type number
(enterprise) when you should be calling out Unknown or National for the Type of Number (TON).
Appreciate it.
Zaid,
1 REPLY
Green
Zaid,
In the UK
If you set TON "Unknown"
You send all national numbers with the leading "0"
If you change to TON "National"
You do NOT send the leading "0"
For more information please see :-
From the BT SIN 261 (http://www.sinet.bt.com/261v5p4.pdf) page 22.
SECTION - Coding of Called Party Number information element:
It is probably easier to set your gateway to UNKNOWN and just drop the access code "9" if
that is what you are using
Regards, Alex. Please rate useful posts.
248
