02-14-2012 08:46 AM - edited 03-16-2019 09:35 AM
Hello!
I want to setup a Cisco Unified Communications solution for an enterprise with more than a thousand users. The company has 3 sites. I want to use one CUCM cluster for all the three sites and Cisco voice gateways for survivability purposes and PSTN access for each site.
Problem is: one of the sites has 62 FXO lines which they want to use with the new system. I dont know of a Cisco voice gateway that can handle that many FXOs.
Please help me out.
I look forward to your helpfull inforamtion.
02-14-2012 08:56 AM
There is now a vg112 which caters for 112 fxs ports
HTh
Alex
02-14-2012 09:01 AM
I know the 112 FXS exists though I have never worked with it, but in this scenario I'm talking about FXOs. Does the 112fxs support fxo
02-14-2012 09:01 AM
You should persuade the customer to convert the FXOs to either digital trunks, i.e. PRIs or IP SIP trunks.
Not only will you get a lot more feature out of it, but you will save initial hardware and implementation costs as well as ongoing monthly telco and system support cost.
HTH,
Chris
02-14-2012 09:04 AM
Kelvin,Chris
Sorry for the dodgy info re FXS , I obviosly did not read this post properly
As Chris (+5 )states you rally need to move to SIP or PRI etc.
Alex
