Community Member
Too much noise while calling
I have MGCP gateway, when i make external call using MGCP gateway. I heared lots of noise.....
Its b/c of Physical layer or service provider issue or E1 card issue.
Thank You
Everyone's tags (4)
1 REPLY
Blue
Do clear counters for the Controller and see if you have error increasing. If yes may be you have problem with the line.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
176
