Total stored voicemail number in Unity 8
Does anyone know of a way to get the total number of voicemail in unity,  The built in unity reports give you mailbox size but that includes all voicemail number.
Thanks much.
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Curtis,
For Unity, the reports section of the Message Store Manager tool probably has
what you need here (it is very good)
http://www.ciscounitytools.com/Applications/Unity/MSM/Help/MSMConsoleHelp_ENU.htm#_Toc110930104
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Hi Curtis,
Cheers!
Rob
Thanks Rob,
Do you know where I can download that tool for unity 8?
Hi Curtis,
You will find it here
http://www.ciscounitytools.com/SiteList/AllDownloads/alldownloads.html
Cheers!
Rob
Thanks much, unfortunately that tool doesn't support unity 8.5 but I found this tool "user data dump" can do the job for unity 8.5:
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
cheers,
Re: Total stored voicemail number in Unity 8
Hi Curtis,
Good stuff my friend
Don't forget that there are 2 separate products here, Unity & Unity Connection
so you have to keep that in mind when looking for solutions. We run Unity Connection
as well and absolutely love CUDD and many other great tools from the awesome Unity Tools
suite. Check some of these out as well...wonderful!!
Audiotext Manager for Connection
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
Port Status Remote Monitor for Connection (rPSM)
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox,  resetting greetings, deleting voice names,  resetting passwords,  removing private lists and a number of other  options you may choose.   For installations where the user base “changes  over” frequently such as  schools this may be a nicer option.  This  option is also allowed for  CoRes installations since it does not involve  the removal of user  objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Cheers!
Rob
445
