Tracing 911 call
Can somebody advise me on the best way to trace 911 calls coming from inside our facility - we are running CUCM 6.1(2) so no SQL DB to look at. This has happened multiple times but we cannot seem to find what extension is dialing it.
Thanks in advance!!
1 ACCEPTED SOLUTION
Re: Tracing 911 call
CAR is a good option, you still can run qrys to informix DB via the CLI
ie
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
java
if this helps, please rate
java
www.cisco.com/go/pdi
ie
java
java
Thanks very much! Great info.
Is there a clean way to export that data into some type of spreadsheet?
Hi javalenc; is there a good Cisco doc explaining CLI queries for CDR lookups on 6.1?
I've also recently moved to 6.1(2). I was running 4.1(3) and had it sending my CDRs to a SQL server making it easy for me to search for calls. The upgrade broke my setup and I was faced with either purchasing ER or IPcelerate for 911 call notification.
After playing with CCM for a while, I was able to configure it to ftp the CDR records to another server. I then wrote a simple app that would get the uploaded CDR files and upload them to my SQL server. While the program is processing the CDR files, it keeps a lookout for 911 calls. If the app finds a call that is no older than 5 minutes it sends an email to a list of predefined uses.
224
