Tracking translation pattern hits
I was wondering how I can see how many times a translation pattern is hit, if this is possible.  We use a software piece from our auto dialer provider that charges us per inbound call on a phone number.  This is a dedicated toll free number with its own translation in callmanager.  Our version of callmanager is 5.1.3.7000-5.  There are basically three different pieces of software and so far our numbers do not match their numbers I also have the telco looking at this number to try and get the information from them but if there is a way to pull it ourselves that would be great.  Also we are looking to do more reporting from callmanager over all and hopefully this will be the first step in getting some of the reporting options figured out.
1 REPLY
Re: Tracking translation pattern hits
No reporting on that, you would need to parse thru CUCM detailed traces and also enable a flag for high complexity traces since they don't show up in regular complexity.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
436
