Traffic router for Multiple CME's
mhering8650
Ok this is probably something I should already know.
But I have a central office with a full blown CM 5.1 install and my site offices are all CME/CUE setups (we have to be able to sever an office relationship fast in some cases which is why site offices are CME instead of SRST)
My question is, is there a way to have my CM act as a call router for the sites, currently whenever we bring a new site online I have to log into each CME and add a dial peer for that sites 5 digit extension range.. With 10 CME's this gets tiresome. I wanted to know if I could create a wildcard pattern to match all unknown extensions and send them to my CM which would then know where to send the calls...
Is this possible?
This is most definitely possible.
What people commonly do in more extreme scenarios (100+ sites) is install a gatekeeper. If you do a little reading you'll see that is the purpose of gatekeeper and centralized dial plans.
Alternatively you can just route everything to CUCM with H323 gateways.
For each site:
-Add the H323 gateway in CUCM
-Add the route pattern for that site in CUCM pointing to the H323 gateway
-Add incoming dial peer on each gateway
-Add outgoing dial peer on each gateway
-Add PSTN connectivity and dial peers on each gateway
Dial peers would look like this:
dial-peer voice 1 voip
incoming called-number .
codec g711ulaw
no vad
dtmf-relay h245-alpha
dial-peer voice 2 voip
destination-pattern [1-8]....
session target ipv4:
codec g711ulaw
no vad
description 10000-80000 DNs
dial-peer voice 3 pots
port 0/0/0:23
destination-pattern 9[2-9].........
direct-inward-dial
description 10 digit dial with 9 access code
hth,
nick
That's exactly what I'm looking for!! We don't have extra hardware to dedicate to being a gatekeeeper so I wanted to see if I could do it with CM :)
Thanks man!!!!
No problem, glad I could help. If there aren't 4 different ways to do it, you're not thinking enough :)
-nick
