transcode incoming calls and IVR
Transcoding is working fine for incoming SIP calls. ITSP supports only g711alaw so it is hardcoded on incoming dial-peer.
How do I transcode incoming g711alaw calls to g711ulaw (its-CISCO.2.0.3.0.tcl) IVR? For transcoder to be invoked incoming and outgoing
dial-peers are needed, but in IVR calls there is only incoming dial-peer.
Now if I call external number from PSTN IVR I don't hear welcome message and after some time forwarded to operator number.
TIA
1 ACCEPTED SOLUTION
Re: transcode incoming calls and IVR
I know the issue , did you try the below config?.
voice class-codec 1
code preference 1 g711alaw
codec preference 2 g711ulaw
dial-peer voice 210 voip
no codec g711alaw
voice class-codec 1
Thank you
please rate all useful information
1- You have to enable transcoder .
2- under the dial-peer which go to IVR , use codec g711ulaw.
3-match transcodig under your telephony-service.
Thank you
Please rate all useful information
To enable transcoding , please find the below:-
voice-card 0
dspfarm
dsp services dspfarm
sccp local (interface)    / preferred voice interface/
sccp ccm x.x.x.x x.x.x.x   identifier 1 version ?   /where the ip address of your CME/
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register  hwxcode
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 10
associate application SCCP
no shut
Thank you
Under
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 4
sdspfarm tag 1 hwxcode                            /must match the name above /
Thank you
The problem is there is no dial peer to IVR, only incoming dial-peer 210. I have working transcode config and if call is
forwarded to CUCM via SIP trunk call is transcoded.
application
service ivr flash:/its-CISCO.2.0.3.0.tcl
  paramspace english index 0
  paramspace english language en
  paramspace english location flash:/
  param aa-pilot 295
  paramspace english prefix en
  param operator 217
description SIP_IN
translation-profile incoming SIP_IN
service ivr
session protocol sipv2
session target ipv4:10.0.0.12
incoming called-number 112233445566
dtmf-relay rtp-nte
codec g711alaw
no vad
voice class-codec 1
no codec g711alaw
voice class-codec 1
Thank you
Thank you, it works now.
i have similar issue, but my
i have similar issue, but my case is dtmf.
incoming SIP call using in-band dtmf but IVR using rtp-nte
dial-peer voice 4 voip
 service meetme  -----> IVR
 incoming called-number 3666
 dtmf-relay rtp-nte sip-kpml
 codec g711ulaw
transcoding is up and running, but dtmf is not working.
ivr-172-28-135-3#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: 172.28.135.3
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.28.135.3, Port Number: 2000
Priority: N/A, Version: 4.0, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 172.28.135.3, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 68, Reported Max OOS Streams: 0
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
655
