Community Member
Transcoder issue
Hi all..
I am confering Transcoder on a 2811. But i am having problem with the conference profile. Its not taking any maximum session and only shows 0 as the option
for max session. As it is not accepting any maximum session , so it is shutdown and i am unable to noshut it.
Here is my related configuration.
2811#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis, Hw Serial#: FTX1142A04J, Hw Revision: 52.57"
PID: CISCO2811 , VID: V05 , SN: FTX1142A04J
NAME: "PVDMII DSP SIMM with one DSP", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC11373FTN
2811#sh running-config
***output supressed***
voice-card 0
dspfarm
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 172.28.80.11 identifier 2 version 4.1
sccp ccm 172.28.80.10 identifier 1 version 4.1
sccp
sccp ccm group 10
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 20 register CFBBZV-03
associate profile 30 register MTPBZV-03
associate profile 10 register TRSBZV-03
switchover method immediate
switchback method immediate
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 3
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
Can anyone further tell me how much each session of PVDM2-16 supports ?
Silver
Re: Transcoder issue
Hello
How many PVDM2-16 do you have? On the sh run I can see that you have a transcoder with Maximum sessions set to 3. If you only have that PVDM avaialble the problem is that DSP resources cannot be shared with conferencing; you can have transcoding and voice channels shared on one DSP, but you cannot share those with conferencing and a PVDM2-16 only has 1 DSP with 16 Channels.
If possible, could you please upload a sh diag?
Thanks!
Community Member
2811#sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.2.0
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11385XTU
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20070926
Chassis Serial Number : FTX1142A04J
Chassis MAC Address : 001d.a107.c910
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 31 33 38 35 58 54 55 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 42 0E C2 8B 46 54 58 31 31 34 32
0x40: 41 30 34 4A C3 06 00 1D A1 07 C9 10 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11373FTN
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 31 33 37
0x20: 33 46 54 4E 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Silver
Hello Munawar,
This is what you have:
Slot 0: C2811 Mainboard
Slot 0: PVDM2-16
As mentioned before DSP resources cannot be shared between conferencing and transcoding; and since you have a PVDM2-16 (1 DSP) configured with a transcoding profile, you won't be able to setup conferencing. You will need yo obtain another PVDM2 for this to work.
Check this link:
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps3115/ps6024/prod_qas0900aecd8016c6ad_ps5855_Products_Q_and_A_Item.html
194
