transcoder probelm
***Transcoding configuratin on a 2821****
sccp local FastEthernet0/0
sccp ccm 172.28.80.11 identifier 2 version 4.1
sccp ccm 172.28.80.10 identifier 1 version 4.1
sccp
sccp ccm group 10
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 20 register CFBBZV-03
associate profile 30 register MTPBZV-03
associate profile 10 register TRSBZV-03
switchover method immediate
switchback method immediate
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 3
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions hardware 3
maximum sessions software 3
i have a PVDMII DSP SIMM with one DSP. But as u can see above the concference profile is shutdown, but when i do it noshut it ask for maximum session number. But in maximum session number it doesnt even takes 1 as max session.only 0 is seen as next to max session number in the IOS sommand for max session number.
Moreover, it also doesnt get registered in the call manager.I have verified, things are ok and ccm side.
any help
Re: transcoder probelm
most probably you're out of resources, on which card is the dspfarm enabled? how many DSPs are in the card?
do a sh voice dsp, it will show all allocated channels. Also if you have any kind of interface (T1, E1, FXS, FXO) they also take resources.
if the show voice dsp shows all used then you need to add more DSPs or free some of them
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
here is the output from sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
------------------------END OF FLEX VOICE CARD 0 ----------------------------
126
