Transcoder question CUCM 6
I see from RTMT that TranscoderResourceAvaible is 6
Is it possible increase this number?
Re: Transcoder question CUCM 6
Any answer?
yes, configure more sessions on your XCODER
it's pretty obvious
java
if this helps, please rate
java
www.cisco.com/go/pdi
If I increase this parameter, will everything work fine?
Isn't XCODER sessions depend on other voice services?
I suppose that If I increase XCODER session, something else begin work worse?
Can you explain this step in more detail or give needed link?
thank you!
Hall of Fame Super Silver
It depends on your available PVDMs in the router (hardware), to increase it you need to have them. The router will tell you if you do or not when you go to re-configure them.
HTH,
Chris
i assume you think this is configured on the CUCM server, NO. this is configured on ISRs with PDVMs, and won't cause anything to work worse
java
java
I understand the procedure of configuration XCODERS.
How many XCODERs can configure on CUCM, as I understand this XCODERs are used by MRGL -> Device Pools.. so only 1 XCODER can work at a time?
An other question: to configurate fault tolerance should I configure second XCODER?
187
