Community Member
Transcoder without Call Manager
Hi All,
I need to know if i can create transcoder and use it without using callmanager. I have two voip system and I need to connect them using Cisco router but these two system use different codecs so I need to create transcoder to solve this.
Re: Transcoder without Call Manager
You can use a CUBE
Transcoding on the Cisco Unified Border Element
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml#transcoding
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
thank you too much but I have some questions:
regarding the configuration I found the following:
telephony-service
load 7960-7940 P00303020214
max-ephones 48
max-dn 48
ip source-address 200.1.1.100 port 2000
sdspfarm units 1
sdspfarm transcode sessions 50
sdspfarm tag 1 MTP123456782012
create cnf-files version-stamp 7960 Jul 29 2002 13:50:03
Can I say I have to make virtual CME to handle the transcoding and MTP??
VIP Super Bronze
No. The CME process only handles locally-registered phones and associated features. You will need to use CUBE to resolve the session border needs.
Community Member
Thank you Jonathan for your  reply,
but I did not understand what you mean exactly
if I configured the transcoder how I can tell the cube to use it ( how I can invoke the transcoder?)
and why I need to put the telephony service configuration ?
Community Member
Any body can give me more clarification?
There was a hint in a "CUBE - ask the expert" on that.
https://supportforums.cisco.com/thread/136540
"CUBE xcoding is triggered purely by a codec mismatch between the two VoIP dial-peers"
The XCODER is SCCP managed, so it forcefully needs CUCM or CME.
That's why you need the telephony service config.
java
java
Community Member
Thank you Martin and javalenc for your support and 5 points for each
but I have one question:
If I have CUBE configured in the CUCM as H323 gateway and in it is connected to SIP provider. In CUCM GW configuration page I checked required MTP and in the same time I configured MTP or Transcoder using DSPs and I registered it with telephony service not with CUCM which MTP the CUBE will use.
I am asking about this because I do not know what is the exact behavior for checking MTP required in CUCM, Dose the CUBE use it for incoming and outgoing calls or one of them?
920
