Transcoding and IVR
SIP provider uses only g711 alaw  codec for SIP trunk which is not compatible with TCL IVR on CME that
requires g711 ulaw. So incoming calls need to be transcoded to g711 ulaw before getting to IVR.
I've configured dspfarm profiles, ccm groups and incoming dial-peer with ivr service applied but system is not working.
What else should I configure for incoming dial-peer to use transcoding? Any links to similar configuration would be appreciated.
CME Version 8.6, c3900e-universalk9-mz.SPA.151-4.M2.bin
1 ACCEPTED SOLUTION
Transcoding and IVR
i am assuming you have an inbound voip dial-peer for incoming calls from the SIP with hardcoded codec in the dial peer as g711a
you need an incoming dial-peer for the ivr type voip where you enforce the codec as g711u
a dial-peer can be set as inbound with the one of the commands below
incoming called number
and
answer-address
if your ivr internal number is 555
use the command incoming-called number 555
and use the command codec g711 u
this way you will make sure the call leg terminating in this dial peer has to use g711 u
then make sure your dsp config a correct and registered
have a look at the below link it might help as well
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
hope this help
Transcoding and IVR
and
answer-address
hope this help
Transcoding and IVR
Thank you, IVR works after changing codec on incoming dial-peer.
369
