Transcoding between CME (G729 to G711)
Im tryng to make  transcoding between two CME Version 15.1(3)T3, both have almost the same configuration but after have dial the phone number I received fastbusy tone not matther in which direction the call is made. Transcoding DSPFarm in both ends are registered.
Scenario:
                                               H323
CME 1 (Codec: G729) <------------------------> CME 2 (Codec: G711)
CME 1
CME-Legacy#show sdspfarm units
mtp-1 Device:CME-TRANSC TCP socket:[1]  REGISTERED in SCCP ver 18/18
actual_stream:4 max_stream 4 IP:192.168.100.1 * 11902  MTP Dixieland keepalive 2102
Supported codec:
                 G711Ulaw
                 G711Alaw
                 G729
                 G729a
                 G729ab
max-mtps:5, max-streams:4, alloc-streams:4, act-streams:0
CME-Legacy#
CME-Legacy#show run
Building configuration...
Current configuration : 2720 bytes
! Last configuration change at 14:03:54 UTC Thu Jun 21 2012
version 15.1
hostname CME-Legacy
boot-start-marker
boot-end-marker
card type t1 0 3
enable secret 5 $1$0iFd$Um7r8JhKS6fMrEpFH64rB0
no aaa new-model
network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-qsig
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2811 sn FHK1246F3KE
archive
log config
  hidekeys
redundancy
controller DSL 0/0/0
controller T1 0/3/0
clock source internal
cablelength long 0db
pri-group timeslots 1-2,24
interface Loopback0
ip address 192.168.100.1 255.255.255.0
interface FastEthernet0/0
ip address 192.168.4.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0
ip address 192.168.3.2 255.255.255.0
encapsulation ppp
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
router eigrp 1
network 192.168.3.0
network 192.168.4.0
network 192.168.100.0
auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
voice-port 0/3/0:23
voice-port 0/1/0
voice-port 0/1/1
mgcp fax t38 ecm
mgcp profile default
sccp local Loopback0
sccp ccm 192.168.100.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate profile 1 register CME-TRANSC
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
associate application SCCP
dial-peer voice 3001 pots
destination-pattern 3001
port 0/1/0
dial-peer voice 3002 pots
destination-pattern 3002
port 0/1/1
dial-peer voice 101 voip
destination-pattern 2...
session target ipv4:192.168.2.1
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 2
sdspfarm tag 1 CME-TRANSC
em logout 0:0 0:0 0:0
max-ephones 4
max-dn 4
ip source-address 192.168.100.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
password leoleo
login
line aux 0
line vty 0 4
password leoleo
login
transport input all
scheduler allocate 20000 1000
end
CME-Legacy#
CME2
mtp-1 Device:CME-TRANSC TCP socket:[3]  REGISTERED in SCCP ver 18/18
actual_stream:8 max_stream 8 IP:192.168.2.1 * 18292  MTP Dixieland keepalive 160
Supported codec:
                 G711Ulaw
                 G711Alaw
                 G729a
                 G729b
                 G729ab
max-mtps:5, max-streams:8, alloc-streams:8, act-streams:0
CME-Lab#
CME-Lab#show run
Current configuration : 7670 bytes
! Last configuration change at 09:50:46 LAPAZ Thu Jun 21 2012
! NVRAM config last updated at 09:46:42 LAPAZ Thu Jun 21 2012
version 15.1
hostname CME-Lab
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-3.T3.bin
boot-end-marker
card type t1 0 2
enable secret 5 $1$jJ.7$b/Yaq0M36fgZSrYpCK5LD/
no aaa new-model
clock timezone LAPAZ -4 0
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 192.168.2.1 192.168.2.20
ip dhcp excluded-address 192.168.3.1 192.168.3.20
ip dhcp excluded-address 192.168.6.1 192.168.6.20
ip dhcp pool DATA
   network 192.168.1.0 255.255.255.0
   option 150 ip 192.168.2.1
   default-router 192.168.1.1
ip dhcp pool VOZ-CME
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
ip dhcp pool VOZ-CUCM
   network 192.168.6.0 255.255.255.0
   option 150 ip 192.168.6.10
   default-router 192.168.6.1
no ip domain lookup
no ipv6 cef
voice translation-rule 1
rule 1 /3.../ /1809544\0/
voice translation-rule 100
rule 1 /2/ /1002/
voice translation-rule 101
rule 1 /1002/ /2/
voice translation-profile SITE-CODE-CallerID
translate calling 100
voice translation-profile SITE-CODE-DNIS
translate called 101
voice-card 0
dspfarm
license udi pid CISCO2811 sn FHK1225F3GX
archive
log config
  hidekeys
redundancy
controller T1 0/2/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.2.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip id zone1 ipaddr 192.168.4.1 1719
h323-gateway voip h323-id CME-Lab
h323-gateway voip bind srcaddr 192.168.2.1
interface FastEthernet0/0.11
encapsulation dot1Q 11
ip address 192.168.6.1 255.255.255.0
interface FastEthernet0/0.50
encapsulation dot1Q 50
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.3.1 255.255.255.0
encapsulation ppp
clock rate 64000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn protocol-emulate network
no cdp enable
router eigrp 1
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.6.0
auto-summary
no ip http server
logging esm config
tftp-server flash:/PHONE/6921_6941_6961/Sccp/cmterm-69xx-sccp.9-2-1-0.tar alias cmterm-69xx-sccp.9-2-1-0.tar
tftp-server flash:/PHONE/6921_6941_6961/Sccp/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:/PHONE/6921_6941_6961/Sccp/SP69xx.0-0-0-8.zz.sgn alias SP69xx.0-0-0-8.zz.sgn
tftp-server flash:/PHONE/6921_6941_6961/Sccp/SCCP69xx.9-2-1-0.loads alias SCCP69xx.9-2-1-0.loads
tftp-server flash:/PHONE/6921_6941_6961/Sccp/SCCP69xx.9-2-1-0.zz.sgn alias SCCP69xx.9-2-1-0.zz.sgn
tftp-server flash:/PHONE/7942_7962/Sccp/apps42.9-2-1TH1-13.sbn alias apps42.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7942_7962/Sccp/cnu42.9-2-1TH1-13.sbn alias cnu42.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7942_7962/Sccp/cvm42sccp.9-2-1TH1-13.sbn alias cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7942_7962/Sccp/dsp42.9-2-1TH1-13.sbn alias dsp42.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7942_7962/Sccp/jar42sccp.9-2-1TH1-13.sbn alias jar42sccp.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7942_7962/Sccp/SCCP42.9-2-1S.loads alias SCCP42.9-2-1S.loads
tftp-server flash:/PHONE/7942_7962/Sccp/term42.default.loads alias term42.default.loads
tftp-server flash:/PHONE/7942_7962/Sccp/term62.default.loads alias term62.default.loads
tftp-server flash:/PHONE/7945_7965/Sccp/cmterm-7945_7965-sccp.9-2-1.tar alias cmterm-7945_7965-sccp.9-2-1.tar
tftp-server flash:/PHONE/7945_7965/Sccp/apps45.9-2-1TH1-13.sbn alias apps45.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7945_7965/Sccp/cnu45.9-2-1TH1-13.sbn alias cnu45.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7945_7965/Sccp/cvm45sccp.9-2-1TH1-13.sbn alias cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7945_7965/Sccp/dsp45.9-2-1TH1-13.sbn alias dsp45.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7945_7965/Sccp/jar45sccp.9-2-1TH1-13.sbn alias jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:/PHONE/7945_7965/Sccp/SCCP45.9-2-1S.loads alias SCCP45.9-2-1S.loads
tftp-server flash:/PHONE/7945_7965/Sccp/term45.default.loads alias term45.default.loads
tftp-server flash:/PHONE/7945_7965/Sccp/term65.default.loads alias term65.default.loads
tftp-server flash:/PHONE/6921_6941_6961/Sccp/DSP69xx.0-0-0-8.zz.sgn alias DSP69xx.0-0-0-8.zz.sgn
control-plane
voice-port 0/2/0:23
voice-port 0/1/0
signal groundStart
station-id name Leo Salcie
caller-id enable
voice-port 0/1/1
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp fax t38 ecm
sccp local FastEthernet0/0.10
sccp ccm 192.168.2.1 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
maximum sessions 4
dial-peer cor custom
name 911call
name localcall
name ldcall
dial-peer cor list 911call
member 911call
dial-peer cor list LD
member 911call
member localcall
member ldcall
dial-peer cor list localcall
member localcall
dial-peer cor list ldcall
member ldcall
dial-peer cor list LOCAL
member localcall
dial-peer voice 9809 pots
corlist outgoing localcall
destination-pattern 99809.......
port 0/3/0
forward-digits 11
dial-peer voice 91809 pots
corlist outgoing ldcall
destination-pattern 991809.......
port 0/3/0
forward-digits 12
dial-peer voice 100 voip
destination-pattern 3...
session target ipv4:192.168.3.2
incoming called-number 2...
codec g711ulaw
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 4
max-ephones 12
max-dn 12
ip source-address 192.168.2.1 port 2000
auto assign 1 to 6
load 7965 SCCP45.9-2-1S
create cnf-files version-stamp 7960 Jun 21 2012 09:37:02
ephone-dn  1
number 2001
ephone-dn  2
number 2002
ephone-dn  3
number 2003
ephone-dn  4
number 2004
ephone-dn  5
number 2005
ephone-dn  6
number 2006
ephone-dn  9  dual-line
number 9999
ephone  1
device-security-mode none
mac-address 503D.E5E9.2001
max-calls-per-button 2
type 6921
button  1:1
ephone  2
mac-address 64A0.E715.F5B2
type 7965
button  1:2
ephone  5
mac-address 503D.E52F.C3E4
button  1:3
ephone  9
mac-address 00F0.1D00.0081
ephone  99
mac-address AABB.CC11.2233
button  1:9
line con 0
line aux 0
line vty 0 4
password leoleo
login
transport input all
ntp master 3
ntp server 192.168.2.1
end
CME-Lab#
Any help would be appreciated
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
If you want to force xcoding..
On cme 2, configure the dial-peer to cme 1 to use G723 codec.
On cme 3, configure this..
dial-peer voice 103 voip
incoming called number 3...
codec g723
no vad
Ensure that your xcoder has G723 codec as one of the codecs.
The call should invoke a xcoder because cisco ip phones cant do G723.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Try this on cme 1
codec g711u
no vad
Then do a test call from cme 2 to cme 1..
it worked, but with dial-peer 103 there's not need to use transcoding because is G711 to G711...At least we know that calls are rececived.
VIP Super Bronze
Re: Transcoding between CME (G729 to G711)
The way you have set it up it cant work.. The reason is because the call cant even get into the gateway. Your call from cme 2 is g711, your incoming dial-peer on cme 1 is g729. So at the ingress of the router the call does not even gets accepted. Transcoding cant be invoked like that.
If you want to do G729 over the IP network or WAN then configure your dial-peer to do G729. Your internal phones will still use G711. So internally you will use G711 and calls to the CME2 will use G729.
In this setup I dont see what you need a xcoder for. IP Phones can do both G729 and G711.
Thanks for you response, I would like to force a call using transcoding just for test porpose.
Do you know how can I achive that? I thought with this scenario I'll be able.
VIP Super Bronze
codec g723
no vad
It worked great!!!! I need to enable the codec G.723 in the trascoding dsp farm in both CME and enable the dial-peer codec G.723 line too.
Just one question more, If both CME have transcoding resources which one will be assignig the trasnscode channel? In my case the CME1 always assign the trasncode channel.
CME-Lab#sh dspfarm dsp all
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    5   27.3.4   UP     1    USED  xcode   1      0x1F        167       170
0    5   27.3.4   UP     1    USED  xcode   1      0x1E        251       235
0    5   27.3.4   UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 4
CME-Lab#
Thanks aokanlawon, Im very glad... today I have learned a lot from you!!!!
VIP Super Bronze
Leo,
I am glad I could help. We are all learning and it is fun to learn and solve problems.
Ideally the side that origiates the call should invoke a xcoder.  This is the call flow.
phone--g711-->cme1-------g723--->|-----g723----->cme2---g711-----phone
We can investiage this further for learning purposes
1. Place a call from cme 1 to cme 2 when the call is establihed, do the ff:
sh voip rtp connection
show sdspfarm sessions
2. Repeat the same for cme 2 to cme 1. From here we should see what we are looking for. You can post the output here.
3276
