transcoding between g.723 and g.711 and/or g.729
Is there any way that I can do transcoding and conferencing between G.723 to and from G.711 and /or G.729 ?
Thanks.,
Green
Re: transcoding between g.723 and g.711 and/or g.729
If using cucm, you can setup regions accordingly and have proper transcoders that support both codecs
check cucm srnd media resources section
I was just trying to configure HW media resource ( 28XX router) using Cisco Online DSP calculator tool. Under the transcoding and coinferencing seciton it never shows g.723 selections. Only g.711 and g.729 are shown.
Green
I do not have catalyst switch in this particular installation . Is there any way that I can configure a router-based conferancing resource for this requirement ?
Green
no
264
