Transcoding without NM-HDV or AIM (only PVDM's on board)
dborota
Dear all,
I have a 2811 router that works as IPIPGW from h.323 to SIP. It has PVDM2's installed on the board of the router (so no NM-HDV or AIM installed).
I cannot figure out how to configure this router to perform transcoding of voice channels. Is it possible with PVDM2's only on the motherboard?
Now with g.711 on complete network it works fine, but it would be excellent if I could implement any other codec.
Any help on this would be highly appreciated!
All the best!
I just did some research, and found that the error message 'Please configure the maximum sessions for this profile and retry' means you do not have enough DSP resources to handle the mixture of analogue and digital voice ports as well as the transcoding profile.
Paste the SH RUN and SH VOICE DSP DETAIL here so I can confirm this, otherwise as a test, power down the router and remove the E1 card, then power up the router and see if you can configure the maximum sessions under the transcoder profile.
10 Replies 10
Jaime Valencia
try
voice-card 0
dspfarm
dsp services dspfarm
then you can follow this doc
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541bf3.html
java
if this helps, please rate
Thanks for help!
However, it did not work for some reason. I followed the instructions and here is what happens:
voice-gateway(config)#voice-card 0
voice-gateway(config-voicecard)#dspfarm
voice-gateway(config-voicecard)#dsp services dsp
voice-gateway(config-voicecard)#exit
voice-gateway(config)#dspfarm profile 10 transcode
voice-gateway(config-dspfarm-profile)#codec g729abr
voice-gateway(config-dspfarm-profile)#maximum sessions ?
<0-0> Number of sessions assigned to this profile
voice-gateway(config-dspfarm-profile)#maximum sessions 0
voice-gateway(config-dspfarm-profile)#no shu
I cannot configure any larger number for max.sessions but 0, and then it does not allow me to turn profile ON. Without this the rest of configuration for transcoding doesnot work.
Do you have any idea what could be wrong?
Thanks in advance!
do a sh voice dsp in order to look at the resources, there is the possibility that something is already using them
that will show up if the DSPs are already in use
java
You can use the telephony service and register the transcoding/conferencing on the local router as a CME resource. It willthen transcode the media for the inwards and outward VOIP calls.
Here is a sample config that shows the concept:
voice-card 0
dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
voice class media 1
media flow-through
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
sccp local GigabitEthernet0/0
sccp ccm identifier 1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register TranscodeCalls
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729br8
maximum sessions 24
associate application SCCP
no shutdown
dial-peer voice 9700 voip
description - G729/H323 calls to CME
destination-pattern 67824497[12].
voice-class media 1
voice-class codec 1
session target ipv4:10.1.1.1
dtmf-relay rtp-nte h245-alphanumeric
dial-peer voice 1000 voip
description - G711/SIP calls to SIP provider
destination-pattern ..........
progress_ind setup enable 3
voice-class media 1
voice-class codec 1
session protocol sipv2
session target ipv4:172.16.1.1
dtmf-relay sip-notify rtp-nte h245-alphanumeric
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 30
sdspfarm tag 1 TranscodeCalls
Thanxs for help!
I am having problem in turning DSP profile in "ON" state.
Please find attached reply from the router on "show voice dsp".
The router has one 4xFXO voice card and one 2-port E1-MFT (only one E1 is used). PVDM2-64 is installed on the motherboard.
Any ideas what could be wrong?
Thanks in advance!
I'm having trouble opening the attachment - can you re-post the file again , or just paste the text straight into the window here.
Appologies for the inconvenience!
Hope this works fine. Thank you!
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g711ulaw 4.4.21 busy idle 0 0 0/0/0:15 31 0 816/87
6
C5510 001 02 g711ulaw 4.4.21 busy idle 0 0 0/0/0:15 01 0 6960/711
9
C5510 001 04 g711ulaw 4.4.21 busy idle 0 0 0/0/0:15 18 0 4228/434
*DSP SIGNALING CHANNELS*
C5510 001 01 {flex} 4.4.21 alloc idle 0 0 0/1/0 02 0 853/
C5510 001 02 {flex} 4.4.21 alloc idle 0 0 0/1/1 06 0 850/
C5510 001 03 {flex} 4.4.21 alloc idle 0 0 0/1/2 10 0 1393/
C5510 001 04 {flex} 4.4.21 alloc idle 0 0 0/1/3 14 0 1404/
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Thanks for help!
I have 2 ISDN E1 interfaces and 4FXO interfaces on this router, with 64PVDM2.
Show run:::
version 12.4
hostname voice-gateway
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
dspfarm
voice service voip
allow-connections sip to sip
redirect ip2ip
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
interface FastEthernet0/0
ip address 192.168.1.208 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.1.111
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
echo-cancel coverage 32
cptone SI
timing hookflash-out 50
connection plar 303
impedance complex2
voice-port 0/1/1
cptone SI
connection plar 303
impedance complex2
voice-port 0/1/2
cptone SI
connection plar 303
impedance complex2
voice-port 0/1/3
cptone SI
connection plar 303
impedance complex2
voice-port 0/0/1:15
sccp local FastEthernet0/0
sccp ccm 192.168.1.200 priority 1 version 4.1
sccp ip precedence 3
sccp
sccp ccm group 1
associate profile 1 register MTP00000000000
description DSPprofile-transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
shutdown
dial-peer voice 100 voip
destination-pattern 5..
modem passthrough nse codec g711ulaw
session target ipv4:192.168.1.200
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 9000 pots
port 0/1/0
dial-peer voice 9001 pots
port 0/1/1
dial-peer voice 9002 pots
port 0/1/2
dial-peer voice 9003 pots
port 0/1/3
dial-peer voice 200 pots
destination-pattern .T
direct-inward-dial
port 0/0/0:15
dial-peer voice 150 pots
destination-pattern 8..
direct-inward-dial
port 0/0/1:15
dial-peer voice 151 pots
destination-pattern 9T
direct-inward-dial
port 0/0/1:15
dial-peer voice 1 pots
service onramp-sffax
incoming called-number 577
direct-inward-dial
dial-peer voice 2 pots
incoming called-number 578
direct-inward-dial
dial-peer voice 102 voip
translation-profile outgoing profile1
destination-pattern 99T
session target ipv4:x.y.x.y
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
authentication abc password abc realm x.y.x.y
retry register 10
registrar ipv4:x.y.x.y expires 3600
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
scheduler allocate 20000 1000
end
Show voice dsp detail:::
If this confirms your assumption, would removing fxo card or turning one ISDN E1 interface to shutdown help on this issue?
Thanks in advance!
Dear friends,
thank you for your patience in waiting for final resolution on this. This gateway was in production, so I had to wait for the right time to shutdown it.
Removing E1 card finally resulted in releasing enough DSP resources to turn dspfarm 'on', and configure transcoding properly. However, since our customer needs this 1E1 interface (but not both) shutting down the second E1 interface on MFT card and removing all configuration related to it also resulted in release of enough DSP resources to have transcoding work.
Thank you all for your help!
