Transcoding
I have a customer which has 2 sites. Site A has all the CCM, Unity Connection & IPCCX servers with no users nor IP Phones, while Site B has all the users, phones and the two 3825 Voice Gateways. Site A & Site B are linked by WAN only.
I have setup 2 regions for each of Site A & B, specifing 'codec to other region' will be G729 while 'codec within region is G.711'.
Now, both of my Voice Gateways on the site with all the IP Phones, do i still need to apply 'transcoding' on the Voice Gateways to do G729 across WAN? Or will G729 work automatically between the two sites without the transcoding?
Hunt
2 ACCEPTED SOLUTIONS
Green
Re: Transcoding
Normmaly Cisco GWs support G729 which IP Phones also support...hence no Xcoding will be needed
Silver
Re: Transcoding
Most of the queuing or IVR functions of IPCC require a G.711 codec. You pick the prompt format when you install IPCC, which did you select? The IPCC SRND gives some good guidance on this.
Green
Re: Transcoding
Re: Transcoding
If that's the case, when would you need to use transcoders then??
I'm a little confused rite now coz I always thought u need a transcoder as soon as u do G729.
Would appreciate your help.
Kind Regards,
Hunt
Silver
Re: Transcoding
Re: Transcoding
While can, always avoid to do transcoding, you can reduce the MOS in a significant amount.
134
