Transcoding
I can't get a router to register as a transcoding in CCM 5.1. It keeps coming up saying rejected. I have configured this many times on CCM4.1 without any issues. Did something change?
Gold
Re: Transcoding
What Router, NM/DSP do you have and can you paste the config and show sccp from the router.
Re: Transcoding
Here you go. I have attached the requested output. I have also attached a sh ver.
Thanks!!!
Gold
Re: Transcoding
There is no config attached, so can you check if the Name used in this profile matches with the CM configuration.
Re: Transcoding
The name matches. I cut and pasted it...
Hall of Fame Super Silver
Re: Transcoding
When you build your sccp confiuration, try not using the CM version, or use 4.1. What IOS version are you running?
Chris
Re: Transcoding
What do you mean "try not using the CM version"?
Re: Transcoding
The router is running c2800nm-advipservicesk9-mz.124-3g.bin.
125
