Transfer call before connected
Hi guys
Is possible the following situation:
Phone A call a external number and before the call conected or while ringing the destination, Phone A wants transfer to Phone B, is possible? Because I not found the transfer button on softkey customize.
Peterson
2 ACCEPTED SOLUTIONS
Re: Transfer call before connected
No, that's not possible.
A call needs to be connected in order for the transfer process to work as it will put the call on hold.
Transferring a Connected Call
Transfer redirects a connected call. The target is  the number to which you want to transfer the call.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/7970g_7971g-ge/english/4_1_3/english/release/notes/413_70f.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hall of Fame Super Red
Hey peterson,
Just to add a note to the great tips from Java and DK (+5 each ) Happy
Friday Java!
If you look at the Softkey template for the Ring Out call state we see that
Transfer is not an available Softkey. There is another way to accomplish
this request, it's not exact but does almost the same thing.
Phone A calls Phone B or vise versa, Phone A presses Confrn, dials
External number. Calls starts ringing at external, Phone A presses
Confrn a second time, Phone B is connected to Ringing external number.
Cheers!
Huff
Yes, its called blind or semi-attended transfer.
What is these phones registered with and what
protocols are we talking about here?
CallManager 8.0
SCCP Phones
H.323 gateways
Just remember
Phone A calls an external number and wants transfer to Phone B before that external number connected (while the external number is ringing).
java
java
Hey peterson,
Friday Java!
Cheers!
Huff
198
