Community Member
transfer calls from unity connection to CUCM not working
I have CUCM 8.0 and UCX 8.0 connected via SCCP. I configure VGW with CUCM as H323 GW with CSS can reach everywhere and VP ports can reach everywhere.
I configure a CTI RP with FWD-All to VM and on UCX configured a call handler and allowed transfer to numbers not in UCX and configured inout ( 0 ) to use system transfer and removed all restrictions for the transfer on UCX.
When I call and select ( 0 ) and put the phone number that I want to call, I receive a messgae "Not able to transfer to this number"
Anyone has any idea to solve this issue??
Hall of Fame Super Red
Hi Tarik,
On the default System transfer restriction table, when I want to transfer to extensions
that begin with 8 but are not part of Unity Connection I need to set;
8???* - Allow
If it was numbers that begin with 5 it would be;
5???* - Allow
Can you give that a try
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Community Member
Hi Rob,
I have allow for * and 8* and it’s not working too
Hi Tarik,
8* should work as well if you are trying to transfer to extensions
that begin with 8 (I just tried this and it worked to transfer to 8467)
On the Caller Input page for the Call Handler is 0 set to go to the
Caller System Transfer conversation and not the User System Transfer conversation?
Is the 8* one of the top rules? And is it set in the Default System transfer restriction table
and not the default transfer restriction table (note no System)?
Cheers!
Rob
290
