Bronze
transfer CCM to new server
Guys
i have currently an MCS-7825 running ccm 4.0. we are in the process of an upgrade with a MCS-7835-H2. i need to put the CCM 4.0 onto this new server. i have the CCM 4.0 software however, it wouldnt detect the new server. what do i need to download for a smooth install of this?
thanks in advance
Re: transfer CCM to new server
you need to ask for the PCD for that server model in order to install the OS.
you cannot download it, you need to order it to get the physical CDs
java
if this helps, please rate
java
www.cisco.com/go/pdi
Green
Which OS is installed?
I remembered some problems when loading CUCM in new servers, which will not recognized because they were released after cucm version.
Some customers upgrade CUCM and that did it.
But let us know exact CUCM version and OS
thanks
Bronze
the customer currently has OS version 2000.2.6 CCM 4.0(2)
they currently only have one server therefore i didnt want to interfer at all with this in case of anything. they ordered 6.1.2 so what i planned to do was make a backup, reinstall 4.0 on the new server, restore to this new server, then upgrade to 4.1 and then to 6.1......hehe, after thinking about it, i decided to pull all the necessary info and recreate (its not a big install). id still like to know though as there is another customer that is currently pursusing this option with the same setup but on a larger scale.
thanks for the responses
110
