12-22-2011 03:11 PM - edited 03-16-2019 08:40 AM
I have problems with transfer, conference and music on Hold in the deployment of this centralized CUCM. The transfer, conference and MoH
functions works fine locally, but didn't work between regions. For example, when I pressed the button to transfer the call between two devices in different regions the softkey change to gray and after few seconds the call is finished. I've configured CFB HW and XCODE in IOS Gateway but the problem still continues.
I hope someone can help me to solve this issue.
12-22-2011 11:06 PM
Hi,Is your CFB Registered on CM?
Have you created MTP and transcode profile?
Faced with same problem with first installation.
That time i wasn't able manual for it,only 3 party forums.
As a rule,you should have these settings created on yor MGCP Gaeway:
But you have to create it through CM Web interface.
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register tr_CC_GW_1
associate profile 3 register CFB_CC_GW_1
associate profile 4 register MTP_CC_GW_1
dspfarm profile 2 transcode
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 16
associate application SCCP
dspfarm profile 3 conference
codec g711ulaw
codec g729br8
codec g729ar8
codec g729r8
maximum sessions 4
dspfarm profile 4 mtp
codec g711ulaw
maximum sessions software 10
12-23-2011 06:44 AM
Hi D_Lebedev,
Previously, I've created the HW resources in IOS and CM Web interface. My configurations is the following:
sccp local GigabitEthernet0/1
sccp ccm 130.61.1.3 identifier 1 priority 1 version 7.0
sccp ccm 130.61.1.4 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate profile 888 register XCODELOCAL
associate profile 777 register MTPG729CAA3
associate profile 666 register MTPG729CAA2
associate profile 555 register MTPG729CAA1
associate profile 444 register MTPG711CAA
associate profile 333 register MTPG729CAA
associate profile 111 register XcodeAltex
associate profile 222 register ConfAltex
dspfarm profile 111 transcode
description "DSP Resources Transcoding"
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 12
dspfarm profile 888 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
dspfarm profile 222 conference
description "DSP Resources Conferencias"
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 10
dspfarm profile 333 mtp
codec g729ar8
maximum sessions software 20
dspfarm profile 444 mtp
codec g711alaw
dspfarm profile 555 mtp
codec g729r8
dspfarm profile 666 mtp
codec g729br8
dspfarm profile 777 mtp
codec g729abr8
maximum sessions software 50
I
I don't have Multicast MoH, just MoH with G711ulaw and G729.
And the CFB is also registered, both SW and HW.
I missing something else?
12-25-2011 09:18 PM
Please place here output with command "sh media resource status"
And go to your Phone by www IP and show logs.
Last log file from Console Logs--/FS/cache/log10
Also,see attach.
Check you have same status-REGISTERED-
10.30.1.30-GW address.
Check with your settings,it should be GW IP,not CM IP only.
12-25-2011 10:54 PM
I get the following information from the show command:
show media resource status
Resource Providers:
Resource Provider ID :: FLEX_DSPRM Status :: REGISTERED
Service Profiles
MTP :: 333 444 555 666 777
TRANSCODING :: 111
CONFERENCING :: 222
Applications :
Application ID : SCCP, Status : REGISTERED
And Transcoder and CFB resources are registered.
Let me get the log, and i'll update in brief.
