Community Member
Transfer/conference only works one way
When transferring calls from site to site over a wan it only works in one direction. I am able to call a station at the other site but as soon as I hit transfer the station at the far end rings busy. If the station at the far end transfers to me, it works. The far end is a SRST. Everythings looks to be programmed correctly. The two sites have their on device pools.
Silver
Re: Transfer/conference only works one way
This sounds like a codec problem - are the calls you are trying to transfer over there originating from a gateway, or just another ip phone in your area?
Mary Beth
Community Member
Hi there,
They are originating from the gateway. Only calls from the outside. Thanks
Silver
So probably your gateway is trying to use a codec that your regions config does not want to allow. The gateway might need to have a media resource group that has a transcoder, or if it is H323, you would want to have a codec class built that would allow the codec that you need to use to get to the other site.
Mary Beth
127
