05-09-2007 09:21 AM - edited 03-14-2019 09:23 PM
I am using the Cisco IP Phone 7960G for CallManager 4.1(3). As a receptionist, I would like to be able to directly transfer people to voicemail (without waiting for the ext. to ring through) when the callee is unavailable. I do not want to idirect them to the general voicemail, and I direct calls for more than one callee/voicemail box, so don't think the manager/assistant proxy line can work for my needs. Any suggestions? Thank you!
05-09-2007 09:31 AM
Take a look at the following link.
http://www.cisco.com/warp/public/788/AVVID/transfer_voicemail.html
Hope this helps. If so, please rate the post.
Brandon
05-09-2007 09:33 AM
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800dea82.shtml
This should work with CCM 4.1(3)
05-09-2007 12:17 PM
Thank you so much for your help! I couldn't seem to find the right page, so I appreciate you finding it for me.
05-23-2007 08:20 AM
We are having the same issue allow we are trying to use the Attendant Console to do it and we get an error message that says fail to transfer to voicemail.
