Community Member
Transfer Directly to VM
I set this up once, but now I can't remember. We used to have an option 5*XXXX if dialed with the XXXX being the user's ext, it would send the caller automatically to voicemail greeting of the person. I can't remember how to set this up.
1 ACCEPTED SOLUTION
Re: Transfer Directly to VM
Transferring Calls Directly to Voice Mail with Cisco CallManager 3.2.2 spD
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800dea82.shtml
java
if this helps, please rate
java
www.cisco.com/go/pdi
u mean this doc?
How to Transfer a Caller Directly into a Cisco Unity Mailbox
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_tech_note09186a008015b963.shtml
java
java
Community Member
I don't think so, if I had a call for someone and I knew they didn't want to take the call I could simply dial 5*1980 and the caller would be transfered to 1980 opening greeting.
java
java
Community Member
Thanks!
626
