Transfer first call while second call incoming
Curtis Lewis
I seem to be a little stuck on this one and wondered if anyone has had a simlar situation?
A user has a cisco 7911 handset and extension number 201, the main office number 612xxx is translated to her ext.
When she is on a call and a second one comes in she is unable to do a Consulting transfer of the first call until the second call stops.
I know the 7911 are dual line phones and it sounds like she won't beable to do this as the first call and the second call are taking up both lines and the consulting transfer would require a third.
But the previous engineer must have implemented a work around for this as s
trangly she was able to do it before the upgarde to uc520_8.6.0. (the config hasn't changed except additional dial peers have been added), call waiting is active however for her extension.
The ephone-dn and ephone config for her handset is below, with the full UC config below that. Any help would be much appricated.
ephone-dn  10
number 201 secondary 612xxx no-reg primary
label 201
description Main reception
name Main reception
call-forward busy 210
call-forward noan 210 timeout 10
transfer-mode consult
ephone-dn  100
number 201
label 201
name Main reception
preference 10
ephone  8
device-security-mode none
video
mac-address 0021.D8BA.0013
username "MPhone"
type 7911
button  1:10 2:100
                         Full Config
version 12.4
parser config cache interface
parser config interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-11.XW8.bin
boot-end-marker
logging buffered 4096
enable secret 5
enable password 7
no aaa new-model
clock timezone gmt 0
clock summer-time gmt recurring
network-clock-participate wic 1
network-clock-participate wic 3
network-clock-select 1 BRI0/1/0
crypto pki trustpoint
dot11 vlan-name VLAN100 vlan 100
dot11 ssid vowlsbcs
   vlan 100
   authentication open eap eap_methods_vowlsbcs
   authentication network-eap eap_methods_vowlsbcs
   authentication key-management wpa
ip cef
ip dhcp relay information trust-all
ip dhcp use vrf connected
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 63.203.35.55
ip domain name Company.local
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
stcapp ccm-group 1
stcapp
stcapp feature access-code
isdn switch-type basic-net3
trunk group  1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 4
rule 1 /612xxx/ /201/
voice translation-rule 5
voice translation-rule 31
rule 1 /^992/ /90xx92/
rule 2 /^993/ /90xx93/
rule 3 /^994/ /90xx94/
rule 4 /^997/ /90xx97/
voice translation-rule 90
rule 1 /\(..........\)/ /90\1/
voice translation-rule 1111
rule 15 /.*/ /612xx5/
voice translation-rule 1112
rule 1 /^999$/ /999/
rule 2 /^112$/ /112/
rule 3 /^9\(.*\)/ /\1/
voice translation-rule 1113
rule 1 /^9/ //
voice translation-rule 1115
rule 1 /^9/ /028/
voice translation-rule 2001
rule 1 /123456/ /501/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-rule 3000
voice translation-profile AA_Profile
translate called 2001
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
translate called 1113
voice translation-profile CallBlocking
translate called 2222
voice translation-profile NI_Codes
translate called 29
voice translation-profile NI_Codes2
translate called 30
voice translation-profile NI_Codes3
translate called 31
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile OUT_NICODES
translate called 1115
voice translation-profile Reception_Profile
translate calling 90
translate called 3000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile rec_Called_4
voice translation-profile rect1_Called_4
translate called 4
voice-card 0
no dspfarm
username admin privilege 15 password 7
archive
log config
  logging enable
  logging size 600
  hidekeys
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
no isdn spoofing
trunk-group 1
interface BRI0/1/1
no ip address
isdn static-tei 0
no isdn spoofing
interface BRI0/3/0
no ip address
isdn static-tei 0
no isdn spoofing
interface BRI0/3/1
no ip address
isdn static-tei 0
no isdn spoofing
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server S00105000200.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
tftp-server term71.default.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:CP7921G-1.0.4.LOADS
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server DistinctiveRingList.xml
tftp-server RingList.xml
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:CampusNight.png
tftp-server flash:CiscoFountain.png
tftp-server flash:Fountain.png
tftp-server flash:MorroRock.png
tftp-server flash:NantucketFlowers.png
tftp-server flash:TN-CampusNight.png
tftp-server flash:TN-CiscoFountain.png
tftp-server flash:TN-Fountain.png
tftp-server flash:TN-MorroRock.png
tftp-server flash:TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
control-plane
voice-port 0/0/0
cptone GB
timeouts ringing infinity
voice-port 0/0/1
cptone GB
voice-port 0/0/2
cptone GB
voice-port 0/0/3
cptone GB
voice-port 0/1/0
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/3/0
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/3/1
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name level1-select
name local
name domestic
name international
name level1-dq
name level1-all
name national
name premium
name mobile
name paging
name personal
name internal
name local-plus
name national-plus
name emergency
name toll-free
name alarm
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list local
member local
dial-peer cor list level1-select
member level1-select
dial-peer cor list level1-dq
member level1-dq
dial-peer cor list level1-all
member level1-all
dial-peer cor list national
member national
dial-peer cor list international
dial-peer cor list premium
member premium
dial-peer cor list mobile
member mobile
dial-peer cor list paging
member paging
dial-peer cor list personal
member personal
dial-peer cor list call-internal
member internal
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member local
member internal
member emergency
member toll-free
dial-peer cor list user-local-plus
member local
member internal
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member local
member national
member internal
member local-plus
member emergency
member toll-free
dial-peer cor list user-national-plus
member local
member national
member internal
member local-plus
member emergency
member toll-free
dial-peer cor list user-international
member local
member national
member internal
member local-plus
member emergency
member toll-free
dial-peer cor list alarm-out
member alarm
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 401
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 501
b2bua
codec g711ulaw
no vad
dial-peer voice 2003 voip
description ** cue auto attendant PSTN number **
translation-profile outgoing AA_Profile
destination-pattern 123456$
b2bua
codec g711ulaw
no vad
dial-peer voice 150 pots
description ** incoming dial peer **
incoming called-number .%
direct-inward-dial
port 0/3/0
dial-peer voice 151 pots
direct-inward-dial
port 0/3/1
dial-peer voice 3003 pots
description rec
translation-profile incoming rec_Called_4
incoming called-number 612xxx
direct-inward-dial
port 0/1/0
dial-peer voice 3000 pots
description rec
direct-inward-dial
port 0/3/1
dial-peer voice 3001 pots
description rec
direct-inward-dial
port 0/3/0
dial-peer voice 3002 pots
description rec
direct-inward-dial
port 0/1/1
dial-peer voice 500 pots
trunkgroup 1
description ** BRI pots dial-peer **
translation-profile incoming Reception_Profile
direct-inward-dial
dial-peer voice 503 pots
trunkgroup 1
direct-inward-dial
dial-peer voice 3012 pots
description rec
direct-inward-dial
port 0/1/1
dial-peer voice 200 voip
mailbox-selection orig-called-num
dial-peer voice 501 pots
trunkgroup 1
translation-profile incoming AA_Profile
direct-inward-dial
dial-peer voice 502 pots
trunkgroup 1
translation-profile incoming VM_Profile
direct-inward-dial
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
b2bua
codec g711ulaw
no vad
dial-peer voice 52 pots
trunkgroup 1
corlist outgoing call-local
description UK FREE NUMBERS - 11 DIGIT
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
destination-pattern 9080[08].......
forward-digits all
no sip-register
dial-peer voice 53 pots
trunkgroup 1
description UK FREE NUMBERS - 10 DIGIT
preference 1
destination-pattern 90500......
forward-digits all
no sip-register
dial-peer voice 54 pots
trunkgroup 1
description UK FREE NUMBERS - <= 10 DIGITS
preference 1
destination-pattern 90800....T
forward-digits all
no sip-register
dial-peer voice 55 pots
trunkgroup 1
description INTERNATIONAL TOLL FREE
preference 1
destination-pattern 900800T
forward-digits all
no sip-register
dial-peer voice 56 pots
trunkgroup 1
description VOICETEXT SERVICES
preference 1
destination-pattern 9180..
forward-digits all
no sip-register
dial-peer voice 57 pots
trunkgroup 1
description UK PSTN OPERATOR
preference 1
destination-pattern 9100
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup 1
description INTERNATIONAL OPERATOR / BLIND DIRECTORY
preference 1
destination-pattern 91[59]5
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup 1
description NON EMERGENCY POLICE SERVICE
preference 1
destination-pattern 9101
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup 1
description NORTHERN IRELAND LOCAL DIRECT DIAL
translation-profile outgoing OUT_NICODES
preference 1
destination-pattern 9[2-9].......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup 1
preference 1
destination-pattern 9[2-9]...T
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup 1
description LOCAL RATE 0845 - 11 DIGIT
preference 1
destination-pattern 90845.......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup 1
description LOCAL RATE 0845 <= 10 DIGIT
preference 1
destination-pattern 90845T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup 1
corlist outgoing call-local-plus
description UK SPEAKING CLOCK - 123
preference 1
destination-pattern 9123
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup 1
corlist outgoing call-national
description LOCATION INDEPENDANT AND CORPORATE
preference 1
destination-pattern 905[56]........
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup 1
description NATIONAL NON GEOGRAPHIC - 11 DIGITS
preference 1
destination-pattern 90870.......
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup 1
corlist outgoing call-national-plus
description SPECIAL SERVICES < 10p min
preference 1
destination-pattern 9087[123].......
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup 1
corlist outgoing call-emergency
description EMERGENCY SERVICES
preference 1
destination-pattern 9999
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup 1
description EMERGENCY SERVICES VOICETEXT
preference 1
destination-pattern 918000
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup 1
preference 1
destination-pattern 18000
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup 1
corlist outgoing call-international
description INTERNATIONAL DIALING
preference 1
destination-pattern 900[1-9]T
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup 1
description LEVEL 1 SERVICES
preference 1
destination-pattern 915[0-4]T
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup 1
description NATIONAL GEOGRAPHIC - 11 DIGITS
preference 1
destination-pattern 90[123].........
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup 1
description NATIONAL GEOGRAPHIC <= 10 DIGITS
preference 1
destination-pattern 901.......T
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup 1
description UK MOBILE NUMBERS
preference 1
destination-pattern 907[1-5,7-9]........
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup 1
preference 1
destination-pattern 90843.......
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup 1
description INTERNET ACCESS NUMBERS
preference 1
destination-pattern 90844.......
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup 1
description 116 HELPLINE NUMBERS
preference 1
destination-pattern 9116...
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup 1
description DIRECTORY ENQUIRIES
preference 1
destination-pattern 9118...
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup 1
description PERSONAL AND RADIO PAGING
preference 1
destination-pattern 907[06]........
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup 1
preference 1
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup 1
preference 1
destination-pattern 9112
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup 1
preference 1
destination-pattern 112
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup 1
preference 1
forward-digits all
no sip-register
dial-peer voice 4000 pots
trunkgroup 1
corlist outgoing alarm-out
description *** Used for Chubb Alarm System ***
preference 1
destination-pattern 0T
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
load 7960-7940 P00308000500
load 7914 S00105000200
load 7902 CP7902080002SCCP060817A
load 7921 CP7921G-1.0.4
load 7931 SCCP31.8-2-2SR2S
load 7941GE SCCP41.8-2-2SR2S
load 7941 SCCP41.8-2-2SR2S
load 7961GE SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7975 SCCP75.8-3-2S
load 7965 SCCP45.8-3-2S
load 7945 SCCP45.8-3-2S
load 7942 SCCP42.8-3-2S
load 7962 SCCP42.8-3-2S
load 7971 SCCP70.8-2-2SR2S
load 7970 SCCP70.8-2-2SR2S
load 7936 cmterm_7936.3-3-13-0
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
max-ephones 32
max-dn 128
ip source-address 10.1.1.1 port 2000
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 401
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
create cnf-files version-stamp 7960 May 08 2013 07:45:47
ephone-template  15
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
ephone-template  18
ephone-dn  5  dual-line
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn  7  dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
call-forward busy 401
call-forward noan 401 timeout 10
ephone-dn  8  dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone-dn  9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn  10
label 201
name Main reception
ephone-dn  11  dual-line
number 202 secondary 612xx5 no-reg primary
label 202
description Curriculum Coordinator
name Curriculum Coordinator
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description Technology
name Technology
ephone-dn  13  dual-line
number 204 secondary 612xx9 no-reg primary
label 204
description Principals office
name Principals office
call-forward noan 210 timeout 15
ephone-dn  14  dual-line
number 205 secondary 612xx0 no-reg primary
label 205
description Bursar office
name Bursar office
call-forward busy 6205
call-forward noan 6205 timeout 25
ephone-dn  15  dual-line
number 206 secondary 612xx5 no-reg primary
label 206
description Vice principal
name Vice principal
call-forward noan 6206 timeout 25
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description Languages two
name Languages two
corlist incoming user-internal
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description Science three
name Science three
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description Geography room
name Geography room
ephone-dn  19  dual-line
number 210 secondary 612xx1 no-reg primary
label 210
description Karen
name Karen
ephone-dn  20  dual-line
number 211 no-reg primary
label 211
description General Classroom
name General Classroom
ephone-dn  21  dual-line
number 212 secondary 612xx1 no-reg primary
label 212
description Pastoral coordinator
name Pastoral coordinator
ephone-dn  22  dual-line
number 213 no-reg primary
label 213
description Religion room
name Religion room
ephone-dn  23  dual-line
number 214 no-reg primary
label 214
description Mobile One
name Mobile One
ephone-dn  24  dual-line
number 215 no-reg primary
label 215
description Mobile two
name Mobile two
ephone-dn  25  dual-line
number 216 no-reg primary
label 216
description Science 1
name Science 1
call-forward busy 6216
call-forward noan 6216 timeout 25
ephone-dn  26  dual-line
number 217 no-reg primary
label 217
description Staff room
name Staff room
ephone-dn  27  dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn  28  dual-line
number 219 no-reg primary
label 219
description 219
name 219
ephone-dn  29  dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn  30  dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn  31  dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn  32  dual-line
number 223 no-reg primary
label 223
description 223
name 223
ephone-dn  33  dual-line
number 224 no-reg primary
label 224
description 224
name 224
ephone-dn  34  dual-line
number 225 no-reg primary
label 225
description 225
name 225
ephone-dn  35  dual-line
number 226 no-reg primary
label 226
description 226
name 226
ephone-dn  36  dual-line
number 227 no-reg primary
label 227
description 227
name 227
ephone-dn  37  dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn  100
number 201
label 201
name Main reception
preference 10
ephone-dn  126
number 6...
description ***XFER TO VM EXTENSION***
call-forward all 401
ephone-dn  127
number A801... no-reg primary
mwi off
ephone-dn  128
number A800... no-reg primary
mwi on
ephone  1
mac-address B8FA.F102.0000
type anl
button  1:5
ephone  2
mac-address B8FA.F102.0001
type anl
button  1:6
ephone  3
mac-address B8FA.F102.0002
type anl
button  1:7
ephone  4
mac-address B8FA.F102.0003
type anl
button  1:8
ephone  5
video
mac-address 0022.9005.EC04
type 7911
button  1:11
ephone  6
video
mac-address 0021.D8BA.6252
type 7911
button  1:12
ephone  7
video
mac-address 0021.D8BA.6EAB
type 7911
button  1:16
ephone  8
video
type 7911
button  1:10 2:100
ephone  9
video
mac-address 0022.905A.4A3B
type 7911
button  1:13
ephone  10
video
mac-address 0022.555F.968A
type 7911
button  1:14
ephone  11
video
mac-address 0022.9005.EB73
type 7911
button  1:15
ephone  12
video
mac-address 0022.9005.EA6E
type 7911
button  1:17
ephone  13
video
mac-address 0022.9005.EB8F
type 7911
button  1:18
ephone  14
video
mac-address 0022.9005.E942
type 7911
button  1:19
ephone  15
video
mac-address 0022.9005.EBD6
type 7911
button  1:20
ephone  16
video
mac-address 0022.555F.9680
type 7911
button  1:21
ephone  17
video
mac-address 0022.9005.EB2C
type 7911
button  1:22
ephone  18
mac-address 0021.553E.A90A
type 7921
button  1:23
ephone  19
mac-address 001E.7ABA.E60A
type 7921
button  1:24
ephone  20
mac-address 0021.55D5.D199
type 7911
button  1:25
ephone  21
mac-address 0021.55D5.D089
type 7911
button  1:26
ephone-hunt 100 sequential
pilot 280
list 210
final 6201
timeout 12
no-reg pilot
banner login ^C
* WARNING!  This system is the property of Blackwater Integrated *
* College and may be accessed only by authorised users.          *
* Unauthorised access to this system is strictly prohibited and  *
* may be subject to criminal prosecution.                        *
^C
line con 0
exec-timeout 30 0
logging synchronous
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input ssh
line vty 5 100
login local
ntp master
webvpn cef
end
Amine Nouasri
Level 3
Level 3
As you said, the ephone-dn should be configured as a dual line. Is there a specific reason why ephone-dn 100 is not?
A workaround would be to use the park soft key. It will free up one line if the call is parked so she can complete the transfer and get back to that call later.
Please rate helpful answers!
