transfer issue
Dear All
we NEED a solution for transferring.
our issue is we want our secretary can transfer the call even before call get connected ( in ring out phase)
issue is the transfer softkey will appear after the call is get connected not before that
how can i meet this requirement?
thanks alot
You can try Feature Control
You can try Feature Control Policy but that do not supported on all phones.
Manish
Not possible, the closest
Not possible, the closest thing you would get is iDivert and that is admin configurable only, and one destination as well. You don't get to dial where to transfer, that depends on your CUCM config.
java
if this helps, please rate
www.cisco.com/go/pdi
36
