Community Member
Transfer License from 2901-SRST Bundle to 2911 V/K9
Hi everyone:
Can I transfer my license permament for 25 phones included on my Cisco ISR 2901 SRST Bundle to another 2911 V/K9?, this is for increase the phones supported by the hardware, from 35 to 50 phones.
Regards!
1 ACCEPTED SOLUTION
Re: Transfer License from 2901-SRST Bundle to 2911 V/K9
Hi.
CME/STST licenses are not installed on router.
Number of supported phone depends by vg model.
Ip phones/feature licenses are "honor based" as mentioned here in hundreds of
posts here in the forum.
So if you need to increase the number of phones change vg model and order as many license as you need.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
Community Member
Thank You Carlo, for your information...
Regards!
220
