08-13-2014 05:57 AM - edited 03-16-2019 11:43 PM
Hi Experts,
Need your help.
we have 2 sites each with a CUCM cluster.
CUCM cluster A on ver 8.6
CUCM cluster B on ver 7.1.5
We would like to move all the phones on cluster B to cluster A and shut down cluster B.
Can we move the DLUs we have on CUCM cluster B to cluster A?
Thanks a lot in advance for your help.
Pete
Solved! Go to Solution.
08-13-2014 09:28 AM
They've done it in the past. Your main problem is going to be moving 7.x DLUs to 8.x so they'll need to make sure you have UCSS or else there may be additional costs. It would be the same as upgrading your 7.x cluster to 8.x.
08-13-2014 06:31 AM
You need to reach licensing for this matter.
08-13-2014 07:43 AM
Thanks a lot for the reply.
Do you know if Cisco is OK with transferring the DLUs from one cluster to another.?
Pete
08-13-2014 09:28 AM
08-13-2014 10:15 AM
Thanks a lot for the helpful answer.
