Community Member
Transfer of call directly to voicemail
Can someone provide a pointer for forwarding calls directly to someone's voicemail instead of ringing their extension?
-Shikamaru
1 ACCEPTED SOLUTION
Community Member
Re: Transfer of call directly to voicemail
Add a CTI RP with *XXXX and CallFwdALL to Voicemail
make sure your default voicemail profile has mailbox mask XXXX listed or this won't work.
Community Member
Community Member
You can set it up so that users can dial * before the extension to send it directly to voice mail. Just create a CTI route for *XXXX and forward all to VM.
218
