Transfer OUT of Voicemail box instead of leaving a message. 8.5
Hey Guys,
I'm trying to figure out how to transfer a call out of a voicemail box, back to a hunt list.
Basically, what we need to do is this:
Call extension and user does not answer. Voicemail greeting prompts me to either leave a message after the tone, or press 9 (or any button) to be transferred to the next available associate.
Is this possible? We are using CUCM 8.5.1 and Unity 8.6.2.
Thanks in advance.
1 ACCEPTED SOLUTION
You would need to configure
You would need to configure the 'caller input' for the mailbox.
In the mailbox:
  1. Edit > Caller Input
  2. Select key '9'
  3. Select 'Call Action > Transfer to Alternate Contact Number'
  4. Enter the extension
  5. Save
HTH,
Adam
In the mailbox:
  2. Select key '9'
  5. Save
HTH,
Adam
We literally figured it out 2
We literally figured it out 2 minutes before your reply. But this is the correct answer. Thank you.
Just clarifying that this is done through Unity.
33
